Masses of Mk3/4/5 parts - far too much to list
Re: Masses of Mk3/4/5 parts - far too much to list
Postby breakfastofchumpions » Thu Jul 13, 2023 9:59 pm
Hi Matt,
Do you have any front suspension brackets for a mk3 (IFS) - the part that links the lower arm to the bumper support on the chassis (aka leaf spring mount on LWBs)? The part numbers are 86VB 3A420 and 86VB 3A421. Also any front coil springs for the same?
Thanks.
Postby MinorMatt » Mon Jul 17, 2023 1:02 pm
I have used coil springs, and a complete mk4/5 front subframe - im not sure if the brackets you mention are the same - but they probably are
Lucas Laser 2000 & IDS
95 N Hallmark (white)
96 P 150 TD 100PS LWB Hi-Top
96 P Autosleeper Duetto
2 x 2006 Mk7s
Postby hitman » Fri Jul 28, 2023 10:47 pm
any inner wing arch repair panels for mk3
hitman
Postby MinorMatt » Tue Aug 01, 2023 12:47 pm
hitman wrote:any inner wing arch repair panels for mk3
No sorry - as far as I know they have never been available? I've seen people mod mk4/5 ones
2 x 2006 Mk7s
Postby hitman » Tue Aug 01, 2023 10:32 pm
no worries,thanks for the info :D
hitman
Postby Maltesefalcon » Wed Aug 30, 2023 6:58 am
Hi,
Do you have yellow temperature sensor with 2 terminals?
Maltesefalcon
Postby MinorMatt » Thu Aug 31, 2023 2:51 pm
Maltesefalcon wrote:Hi,
Will PM you
2 x 2006 Mk7s
Postby redzi3001 » Sun Feb 18, 2024 9:57 pm
Hello I'm looking for a grill from MK4? MK5 front bumper? A 3-seater bench behind the driver?greetings
redzi3001
Postby baba2000 » Mon Feb 26, 2024 12:23 am
Hi, wondered if you have a good mk5 2.5 DI alternator year 2000 . Thanks.
baba2000
Postby Peterwp » Tue Mar 05, 2024 2:39 pm
Hi, looking for a new OEM or not or intact second hand, underbonnet insulation for mk4 1994 190L banana engine.
L Reg Mk4 190L Based Motorhome, 97K, Banana and 'Get to 60 if you are lucky' Auto
Peterwp
Postby MinorMatt » Wed Mar 06, 2024 11:27 am
Peterwp wrote:Hi, looking for a new OEM or not or intact second hand, underbonnet insulation for mk4 1994 190L banana engine.
Unfortunately I think lots of people are :( but they don't seem to exist. I have 2 vans that need that too
2 x 2006 Mk7s
Postby meerkatmag » Sun Apr 14, 2024 12:22 pm
Hi, Do you have a power steering pump bracket for mk3,4 or 5?
1988 transit MK3 2.5di na
meerkatmag
Postby Chug » Sun Apr 14, 2024 12:52 pm
If Matt hasn't got one I think I have one kicking about and I'll have a look.
Chug
Postby meerkatmag » Sun Apr 14, 2024 7:09 pm
Chug wrote:If Matt hasn't got one I think I have one kicking about and I'll have a look.
Cheers, let me know if you find one!
meerkatmag
Postby MinorMatt » Wed Apr 17, 2024 10:10 am
meerkatmag wrote:Hi, Do you have a power steering pump bracket for mk3,4 or 5?
I think I have both parts of the bracket for mk4/5 (the one on the bottom nearside of the 2.5Di engine)
2 x 2006 Mk7s
