Transit MK6: unfinished swap of the 2.4 TDDi engine on the B
Postby wojciech » Mon Mar 11, 2024 1:37 pm
The following thread appeared on the Polish portal Elektroda, but unfortunately the author milosz_wwl - despite his great advancement - did not finish it. It is not known whether he finished the work, whether he resigned or whether he is still alive... It's a pity, because the scope of the work was impressive. Thus...:
Hello everyone.
I will try to describe my struggles with the engine swap in the Mk6 Transit.
By default, the car had a 2.4tddi 90 HP engine, but as expected, the injection pump failed. Due to the general condition of the engine (leaks, etc.) and low power, I did not want to invest in it.
This is how the idea of swapping the engine for something less faulty and more powerful was born. The choice fell on the M57D30 from BMW.
I left the gearbox from the Transit because the BMW gearboxes have shorter gear ratios.
The m57 adapter for Transit mt82 2.2 is available in the UK but I wasn't sure if it would fit and it costs £500.00.
photo 1: I designed my own adapter, which I burned on a laser from 10mm sheet metal.
photo 2: Next, fitting the gearbox
photo 3, 4, 5: Making room for the starter
wojciech
Re: Transit MK6: unfinished swap of the 2.4 TDDi engine on t
Postby wojciech » Mon Mar 11, 2024 1:54 pm
To connect the Ford flywheel with the BMW crankshaft, I drilled a 260 mm hole in it.
photos: 6, 7
Then a few holes
photo: 8
And the flywheel is ready
photo: 9, 10
wojciech
Postby wojciech » Mon Mar 11, 2024 3:32 pm
Photo 13. This is what it looks like after grinding and stuffing with Kevlar.
You'll take it off
Photo 14. the bulkhead wall needs to be modified a bit.
Photo 15. The bowl was a bit of a nuisance
wojciech
Postby wojciech » Mon Mar 11, 2024 3:45 pm
The clutch is ready to install the gearbox
I made the clutch head mushroom 7mm longer
I turned the rear support of the box, which moves it back by about 50mm
And the engine sits
wojciech
Postby wojciech » Mon Mar 11, 2024 3:48 pm
The front belt fits and there is about 70 mm left in front of the shaft pulley for the radiator
wojciech
Postby wojciech » Mon Mar 11, 2024 3:51 pm
Well, a year has passed - and we don't know how this story continues.
Pity... :?: :(
wojciech
Postby dumper » Mon Mar 11, 2024 4:59 pm
I think there is a thred on here of someone fitting a bmw engine in a transit and Alvin the crack on YouTube has fitted a v8 bmw engine in a transit
Re: Transit MK6: unfinished swap of the BMW eengine
Postby wojciech » Tue Mar 12, 2024 9:27 am
The first BMW V8 engine in the Transit was installed by Marcin Wicik (in Poland), he called it Drift Bus (2011). Marcin Wicik is a famous competitor and Polish Rallycross champion. He also has a large company selling parts for Transit.
http://wicikmotorsport.com/taxi.php
As for the above thread - I think that the project has not been completed, the owner has probably lost his strength when it comes to engine accessories and electronics.
wojciech
Postby cristianbells » Thu Jun 12, 2025 7:31 am
wojciech wrote:The following thread appeared on the Polish portal Elektroda, but unfortunately the author milosz_wwl - despite his great advancement - did not finish it. It is not known whether he finished the work, whether he resigned or whether he is still alive... It's a pity, because the scope of the work was impressive. Thus...:
Hello everyone.
Great work taking on such a challenging swap! Designing your own adapter plate is impressive, and it’s clear you’re carefully thinking through the details, especially with fitting the starter and retaining the Transit gearbox.
cristianbells
Postby cristianbells » Mon Jun 16, 2025 3:26 pm
Hello everyone.
Gambling bizzo-casino.co.com is deeply ingrained in Australian culture
cristianbells
Postby cristianbells » Mon Jun 30, 2025 3:56 pm
Hello everyone.
photo 2: Next, fitting the gearbox,at website pt aqui
That’s an awesome swap — love that you went with the M57 for more power and reliability. Designing your own adapter plate is seriously impressive; can't wait to see how it all comes together!
cristianbells
