Circuit diagram filter housing sensor.
Postby sherwoodcycles » Mon May 15, 2023 11:25 am
This should apply to many variants....I have looked on a mk7 and a custom circuit diagram, but cannot see the sensor that's located on the fuel filter housing at the top. Not sure if it's a sensor or switch but regardless, I cannot find it on the circuit diagrams. Any advice would be appreciated.
Greeny
sherwoodcycles
Re: Circuit diagram filter housing sensor.
Postby metalworker0 » Mon May 15, 2023 4:47 pm
Not knowing ..guess it may be water in fuel sensor .
Postby knobby1 » Mon May 15, 2023 8:00 pm
sherwoodcycles wrote:This should apply to many variants....I have looked on a mk7 and a custom circuit diagram, but cannot see the sensor that's located on the fuel filter housing at the top. Not sure if it's a sensor or switch but regardless, I cannot find it on the circuit diagrams. Any advice would be appreciated.
Euro-4 or Euro-5..?? They are different.
If Euro-4, they don't have a sensor at the top....if you're talking about the "yellow" thing at the top..?? Most people think it's a pump or primer...but it's actually just a filter clogging/blockage indicator.
Postby sherwoodcycles » Tue May 16, 2023 8:30 am
Cheers for the reply. It's this one...
Greeny
sherwoodcycles
Postby knobby1 » Tue May 16, 2023 8:13 pm
sherwoodcycles wrote:Cheers for the reply. It's this one...
Ah...so it's a Euro-5. I believe the sensor is a filter "differential pressure" sensor, if I understand it correctly, it senses "before and after" filter pressure and determines whether the filter is blocked or not.
Postby sherwoodcycles » Wed May 17, 2023 12:05 am
OK thanks. I don't seem to be able to find it on my circuit diagrams but at least I know what it's there for.
Greeny
sherwoodcycles
Postby esoj » Sat Mar 23, 2024 5:02 am
can you block the indicator and do away with it
esoj
Postby knobby1 » Tue Mar 26, 2024 7:52 pm
esoj wrote:can you block the indicator and do away with it
It may throw a fault code if not present, I suspect the PCM is expecting a signal of some sort from it.
