Scanner won't connect to my ecu
Postby plvcrmn » Sun Jan 01, 2017 9:51 pm
Transit connect 04 tdci 90ps , my diagnostic system won't connect to the ecu , it is working on other cars , iv also tried a different system and that won't connect also ,,,
plvcrmn
Re: Scanner won't connect to my ecu
Postby blue estate » Sun Jan 01, 2017 9:54 pm
if OBD they may not work as diesels weren't OBD till 2004 and yours may have been built in 2003 but not registered till 2004
Also pull and check all fuses as ford have a habit of changing fuse diagrams
blue estate
Postby plvcrmn » Mon Jan 02, 2017 12:17 am
I have tested the obd socket for 12 volt and it is there , also it did used to connect , and if it wasn't obd compliant then how are the injectors programmed
plvcrmn
Postby Jim Archer » Mon Jan 02, 2017 8:09 am
plvcrmn wrote: ...... and if it wasn't obd compliant then how are the injectors programmed
Via Ford IDS protocol. Some readers connect OK, some don't.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby plvcrmn » Mon Jan 02, 2017 11:48 pm
But why would it have worked a few months ago and not now ?
plvcrmn
Postby knobby1 » Tue Jan 03, 2017 2:52 am
plvcrmn wrote:But why would it have worked a few months ago and not now ?
Your scanner might be fugged...not unheard of.
Mk6 isn't ODB-II compliant either, so just plugging any old scanner into it probably won't work. F-Super and IDS will work on Mk6.
Postby plvcrmn » Tue Jan 03, 2017 10:15 am
Well another pointless reply , firstly if you read , it isn't f*** because it works ok on other vehicles and its a connect not a bag of rotting crap mk6 , so if you cannot be bothered to read a full post also if you don't know sod about what I'm asking then DONT REPLY
plvcrmn
Postby amlav » Tue Jan 03, 2017 11:46 am
plvcrmn wrote:Well another pointless reply , firstly if you read , it isn't f*** because it works ok on other vehicles and its a connect not a bag of rotting crap mk6 , so if you cannot be bothered to read a full post also if you don't know sod about what I'm asking then DONT REPLY
No need to be that nasty . After all people here are trying to help with they opinion . It is realy up to you to decide if the help given is relevant to your problem .
If scaner did connect previously but not know it could be wirring loom issue(s)........but ........this is only a sugestion . :roll:
amlav
Postby ake » Tue Jan 03, 2017 5:20 pm
Check all the relevant pins are still in place and not damaged on diagnostic plug
Check you have 12v on both permanent feed and ignition switched feed
And calm down and stop being a dick.
Postby karl » Tue Jan 03, 2017 5:30 pm
ake wrote:Check all the relevant pins are still in place and not damaged on diagnostic plug
k.
lol :lol:
karl
Tranny Lover!!!
Postby Jim Archer » Thu Jan 05, 2017 8:53 am
So ..... you wait til several posts in to tell us it 'used to connect up, and now it doesn't'.
Was it this same particular vehicle?
Or another one?
If the same one, what have you dicked about with on it since?
Data port is direct to the ECU via a couple of fuses, trace the pins back to the ECU plug and check continuity.
HTMH
Jim
Jim Archer
Postby paul2012 » Thu Jan 05, 2017 8:59 pm
plvcrmn wrote:Transit connect 04 tdci 90ps , my diagnostic system won't connect to the ecu , it is working on other cars , iv also tried a different system and that won't connect also ,,,
2000-2006 Transit Connects are EOBD. :idea: - No OBDII device will read/program PCM. (Just like Transit mk6)
Only Connects from 2006 onwards are OBDII Compliant.
Ford IDS will work no problem. A cheaper alternative is this F-Super2 :arrow:http://www.ebay.co.uk/itm/F-Interface-S ... Sw~OdVZH1B. It will work on your connect & program injectors. :wink:
It will also work on Transit mk6's
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby Jeromemc » Thu May 09, 2024 7:05 pm
Do you have Chassis ground on pin 4, signal ground on pin 5, SAE negative on pin 10, SAE positive on pin 2, Battery positive on pin 16 and can-bus high pin 6 and can-bus low on pin 14?
Jeromemc
Postby knobby1 » Wed May 15, 2024 10:22 am
Jeromemc wrote:Do you have Chassis ground on pin 4, signal ground on pin 5, SAE negative on pin 10, SAE positive on pin 2, Battery positive on pin 16 and can-bus high pin 6 and can-bus low on pin 14?
Thread is 7 years old...and the person you're replying to hasn't been back here since Jan of 2021.
Postby Altransit » Wed May 15, 2024 11:06 am
That's true, of course, but I approved the post in case the information helps someone else in the future 8)
