Turns over but won't start
Postby VG1997 » Thu May 23, 2024 5:36 pm
Hi there all.
I have 1997 Ford Transit Van 2.5 litre turbo
Diesel. Has fuel in it. Winds over but won't start. I've checked fuses etc . I'm at Witts end over here in Australia. Any advice or knowledge be much appreciated Kind
Regards oh my Engine is GB OHV .Delphi lucas pump etc
VG1997
Re: Turns over but won't start
Postby Altransit » Thu May 23, 2024 6:29 pm
Checked the timing belt?
Postby VG1997 » Sat May 25, 2024 4:29 am
Altransit wrote:Checked the timing belt?
Hi there sorry for late reply & thank you for your Reply. Has new Timming belt in it .
VG1997
Postby MinorMatt » Thu May 30, 2024 9:49 am
Do you have an immobiliser? LED in dash or headlining?
Postby VG1997 » Fri May 31, 2024 4:04 am
MinorMatt wrote:Do you have an immobiliser? LED in dash or headlining?
Not sure what you mean .
VG1997
Postby MinorMatt » Tue Jun 04, 2024 1:30 pm
I will guess you don't then....
Have a look in the engine bay. There is a fuse box attached to the inner wing on the drivers side below the battery.
In there is a half sized brown relay. if you link the 2 big terminals it should start and run (as a diagnostic only). If it fixes the problem - replace the relay
