Starting issue
Starting issue
Postby Pat Marsden » Thu Jun 06, 2024 7:33 am
Hi All, ive a 2020 185ps Sport, 39k, and am experiencing some starting issues. Before I take it to Ford id see if anyone else has experienced the same.
Cold start is fine, wait for the preheat light to go out and it fires straight away. Drive to my job and at the end of the day the preheat light doesnt come on and it just turns over but doesnt fire. It times itself out and on the next attempt it will eventually splutter a bit and then fire up. Once running its ok and if I stop on the way home it will start again. Seems to be if left for any time it has the issues.
Pat Marsden
Re: Starting issue
Postby andz327 » Fri Jun 07, 2024 12:38 am
Check for codes and see what their about
andz327
Re: Starting issue
Postby Pat Marsden » Fri Jun 28, 2024 6:50 am
No fault codes showing and log of previous starts not showing any issues. Logically Im thinking that it could be the glow plug control module/relay? Gradually getting worse as the glow plug light doesnt come on at all now, even first thing.
Pat Marsden
Re: Starting issue
Postby Gusxl250 » Thu Sep 04, 2025 9:24 pm
Hi pat having the same problem custom 2.0 ecoblue changed the relay did not fix problem
Thinking it might be temperature sensor
Ford transit custom 2.0 ecoblue 170 5700 miles
Gusxl250
Re: Starting issue
Postby Muddyfunster » Mon Oct 20, 2025 8:44 am
Hi both,
Did either of you manage to sort this issue?
I'm having the exact same issue on my 21 custom when left for a while. I was thinking glow plug module replacement, but not so sure now I've read this thread.
Muddyfunster
Re: Starting issue
Postby Gusxl250 » Thu Nov 20, 2025 9:00 pm
Hi on the forscan live data on the coolant temp sensor 2 it was reading -40
Fitted new sensor thought that fixed it glow plugs still not working at certain times
Still working first thing in morning every time
A bit stumped
Gusxl250
Re: Starting issue
Postby Muddyfunster » Thu Dec 11, 2025 7:36 pm
Update on my situation
My starting issue developed somewhat
Thought it was a fueling issue so booked it in to Ford. No issues found, so they suspect compression issue... compression test confirms low compression on 2 cylinders... head needs to come off now :(
Bills starting to add up!
Muddyfunster
Re: Starting issue
Postby Gusxl250 » Sun Dec 14, 2025 1:46 pm
Hi muddy what mileage is on your van?
Gusxl250
Re: Starting issue
Postby Muddyfunster » Tue Dec 16, 2025 8:57 pm
Mileage is currently just over 80K. Mine is a 21 plate. Needs a new cylinder head as not repairable apparently.
I know of a Transit pick up ( 2L eco blue) with 22k on the clock that has had the same problem and needs complete new engine.. a 10k fix :shock:
Muddyfunster
Re: Starting issue
Postby mompracen_bs » Fri Jan 09, 2026 9:24 am
Muddyfunster wrote:Update on my situation
https://www.youtube.com/watch?v=S6V29CuN_Y8
Corroded valve seats, apparently due to “poor” material used by Ford, a defect that was obviously never acknowledged in vehicles outside of warranty.
Initially, it seemed to affect Transit+TransitCustom vehicles from the early years of production (2016>2018), but over the years, several cases have also emerged in vehicles around 2020.
mompracen_bs
Re: Starting issue
Postby Gusxl250 » Mon Jan 12, 2026 11:56 pm
Hi did Ford replace head under warranty?
Is your van going ok now ?
Not sure what to do with mine still starting in morning go to work then leave it for a couple of hours if the glow plugs don't activate it cranks but won't fire
Leave it for five minutes then glow plugs activate fires up ok
Gusxl250
Re: Starting issue
Postby Muddyfunster » Tue Mar 24, 2026 9:48 pm
So mine turned out to be 2no valve seats at fault. New head fitted by Ford (out of warranty) at a 4k cost. Caught it quite early. Some need complete new engine at about 10k cost!
Starts on the button every time now. I have since activated the exhaust filter Status on the display so I know when to go on a drive to cause a regen.
Seems to be anything with the 2L Ecoblue engine could have similar issues and not necessarily high milers. I know of a Transit pickup locally with only 20K miles has the same issues I had.
Muddyfunster
Re: Starting issue
Postby Gusxl250 » Sun Mar 29, 2026 10:32 pm
Hi muddy thanks for the update
Will have to do compression test on mine
Gusxl250
Re: Starting issue
Postby Colr6 » Sun Mar 29, 2026 11:19 pm
Just taken mine apart for exactly the same reasons 2021@ 35k replaced 8 exhaust valves due to blow by and corrosion. Seats recut. The piston tops on mine were even corroded so they’ve been changed as well.
Colr6
Re: Starting issue
Postby Muddyfunster » Tue Mar 31, 2026 3:53 pm
Colr6 wrote:Just taken mine apart for exactly the same reasons 2021@ 35k replaced 8 exhaust valves due to blow by and corrosion. Seats recut. The piston tops on mine were even corroded so they’ve been changed as well.
Blimey that's a lot of work required. Are you doing it yourself or having to pay someone?
Muddyfunster
Return to Transit Custom
