Flashing Glow Plug Light
Re: Flashing Glow Plug Light
Postby knobby1 » Wed Jun 05, 2024 10:39 pm
Dave Deeda wrote:So..I have sorted out Forscan and run it and came up with some codes..I managed to delete all but one, which is p1665, which apparently associated with the Fuel injectors. Because of what happened leading to it, which was an electrician bridging a headlight relay to try and fix headlights not working; rather than thinking it's mechanical, Im thinking it's an issue of current not getting through somewhere, ie a short.
There seems to be current getting to the ecu ok.The van turns over, will not start.Glow plug light still flashes.is there a straightforward way to see if current is getting to the diesel pump and injectors, because the pump is quite inaccessible ?
Also I have read on another thread somewhere..is there some sort of ecu specifically attached to the diesel pump ? Or maybe I'm getting confused.
This has been going on at least a month, any more help greatly appreciated,
Dave
P1665 is a failing pump EDC, not injectors. Your injectors are mechanical...so they won't have any current going to them.
Postby Dave Deeda » Thu Jun 06, 2024 11:56 am
Thanks, do I need a whole new pump, or just the EDC ?it's on a Ldv with 2.4 Transit, I think it's the VP30..and is it attached to the pump ?
Dave Deeda
Postby knobby1 » Thu Jun 06, 2024 11:04 pm
Dave Deeda wrote:Thanks, do I need a whole new pump, or just the EDC ?it's on a Ldv with 2.4 Transit, I think it's the VP30..and is it attached to the pump ?
The EDC can be repaired....there's people on fleabay who do them....they often blow a mofset on the circuit board inside the EDC box.
Many people just fit a new or reconditioned pump and be done with it....but it's much more expensive than getting the EDC repaired.
Postby Dave Deeda » Fri Jun 07, 2024 3:22 pm
Thanks for all the input..now I have some direction, hopefully can get it up and running again soon
Dave
Dave Deeda
Postby gsc1ugs » Mon Jun 10, 2024 5:45 pm
I have this same problem, flashing glow plugs and code P1665 - Question, how do i know its defineatly the EDC and not something else? my scanner after some hassle dug up this code and it wont erase because its EOBD
gsc1ugs
Postby knobby1 » Mon Jun 10, 2024 8:45 pm
gsc1ugs wrote:I have this same problem, flashing glow plugs and code P1665 - Question, how do i know its defineatly the EDC and not something else? my scanner after some hassle dug up this code and it wont erase because its EOBD
What code reader are you using..?? P1665 is a loss of communication with the EDC...could just be a poorly connection/wiring, (worth checking)....or the circuit board inside the EDC may be faulty leading to lost communication.
Postby gsc1ugs » Tue Jun 11, 2024 6:46 am
Xtool d8 ive checked wiring continuity is fine
gsc1ugs
