MK4 Mini-Horsebox Build, Bank Holiday Weekend (56k Beware)
Postby WildGoose » Tue Aug 28, 2007 6:58 pm
The reason for the purchase of our transit at the time, was as a reliable towing vehicle that didnt cost the earth to maintain and run, like your average 4x4, however it adapted into another purpose when, she - who probably knows best :wink: - developed an interest in the smaller members of the equine community, and a pair were invited to join the family :lol:
Up until now, we were just throwing some hay bales in the back and making a makeshift pen up, but this was less than ideal, and a hassle to keep removing them, cleaning up etc. Also wanted a more professional, safe, and secure way for them to travel.
So over to me getting a bit bored in the run up to the bank holiday weekend, thought it was about time to make a start on.... something, wasnt quite sure what, and without actually drawing anything down on to paper, off I went to focus to lighten my wallet somewhat.
Firstly we decided that we would like them to enter through the side loading door, and load sideways on, this also would maximise the availible space around the wheel arches for other things.
So for the first night, in went some cross beams.
Hand space is fairly limited inside those upright bulkheady bits, but just enough to get a nice solid nut and bolt in place. The rearmost beam I pop riveted brackets into place, and bolted via the brackets, again a surprisingly strong setup. Both beams support my weight without any horrible bending noises, or tearing of metal :P
The idea of all this, was for it to be modular and removeable, so if needed the van could be returned to its regular state, and used for tip runs, or indeed further enthusiatic runs to focus :lol: . I decided that I would try and faciliate everything but the front bulkhead to be removeable.
The second day, I spent time building onto the crossbars a basic frame to create the partitions. The biggest blisters were created from all the manual screwing right in the centre of my hand :x Proper screw bits for my electric drill were definately on the shopping list for day 3.
Also started work on building the ramp, that would hopefully locate into the step on the side loading door. But also fit nicely into the back of the van when not in use.
Day 3, and off to get the plywood. Wanted large sheets, so each partition would have a complete bit, and not look too hotch potch. Unfortunately after buying the 8x4 sheets and getting them outside I realised they werent going to fit in the van. So queue some funny looks as I start cutting them to size right there in the car park, using trolleys laid on their side as workbenches 8)
Finished off the ramp first. When I got back. Surprisingly light, given how bulky it looks. Little bit awkward to move around, but it shouldnt get broken in a hurry. (Bonus points for spotting the white rabbit, 'Where's Wally' stylee)
Next built the frame for the centre partition, the vague plan here was to bolt it in at 4 points in the van, using sliding gate bolts. This would hopefully also allow it to pivot to assist loading the first horse without it getting caught on the side door. Sounded ambitious to me, but seemed to work quite well. Riveted brackets onto the metal cross beam in the roof to move the position of the required holes about 2 inches further forward. Due to metal roof beam not being in the place I required it :P
On goes the plywood, and its beginning to look like something. I purchased a jigsaw to assist at this stage, and it gives a surprisingly tidy and accurate finish if measured out properly, just tidied up the edges with a bit of sand paper.
The front bulkhead, the only permanent fixture, just before applying the plywood.
The rearmost partition is secured in three points, using long roofing bolts and wingnuts. This allows it to be removed quickly and without tools. The brackets remain a permanent fixture being riveted to the van, but shouldnt cause much of an obstruction.
Finally, a breast bar to stop them headbutting the offside wall panels, or getting tangled up in the flange type metal near the walls. Again the breast bar is removable, secured with M8 bolts and wingnuts. You can also see the pivoting action of the centre partition here. Incredibly solid whilst all four bolts are in place, and doesnt rattle on the move, which is excellent news :)
So, last bits of plywood finished off as neatly as possible, with probably far too many panel pins. Maybe I just like my hammer :wink:
And there you have it.
Washed the green slime off the roof as well, just to make a bit of an effort to detach the van from the pikey image :wink:
Bedded up and ready to go, the plan will eventually be, to cut rubber matting in two bits, to fit in place in the stalls, gives more grip and support for the little ones, as well as being easier for us to remove and clean than the straw.
Trying to coax the nervous buggers into working out how the ramp works... Got there in the end, it is surprisingly difficult to force these little ones to do anything, the strength and determination to resist is very much in place from an early age.
And finally, the happy customers, loaded and ready to go. You can see here the ramp in its stowed positon, actually doubles up as a full width shelf in the rear, sitting on the wheel arches. Kit can be stored underneath, leaving space for hay bales or bulky items above.
I'm not a hobby DIY'er by any stretch of the imagination, and this is perhaps the first time i've lifted a saw, drill or hammer in anger, since woodworking at school. Really enjoyed it, very satisfying work.
I'm really pleased with the results, the bill minus the tools purchased for the job, was around the £130 mark. I'm sure there will be plenty more in the pipeline to be added. Once you get started with these things, there is always extra bits you want to add.
Now just hope our trusty old transit goes the distance. Thanks for reading! :D
WildGoose
Postby Gromit » Tue Aug 28, 2007 10:11 pm
Very clever and a nice tidy job there.
8) 8) 8)
On the plus side you`ve got something to pull the van home with if it ever breaks down or runs out of fuel.
:D
Cut, grind, weld, cut, grind, weld........just another day in the life of a Smiley owner.
Gromit
Postby djswampy » Tue Aug 28, 2007 10:52 pm
I couldn't work out what the hell was going in this van. Mini horse box?? Then I see the little horses and it made sence. Neat little idea. certainly a different use for a van of that size. Congratulations on the work.
Gromit wrote:On the plus side you`ve got something to pull the van home with if it ever breaks down or runs out of fuel.
Fantastic idea.
djswampy
Postby DOL » Tue Aug 28, 2007 11:56 pm
nice work 8) very unique :D
Image 1 by 1 the penguins keep stealing my sanity!!
DOL
Formerly known as Dafodol.
Postby jamieo » Wed Aug 29, 2007 12:03 am
Well done mate, that's the smallest horsebox I have ever seen. :D
Blue 1998 Ford transit 2.5di 70ps 120 swb low roof Mk5 with 5 seats. 1.5 turns on pump, egr butterfly removed and a stainless steel Urban X funnel air filter fitted. Now happily burning SVO.
jamieo
Postby Richy Rich » Fri Aug 31, 2007 1:26 am
Nice job there mate. Best start buying these in bulk!! :lol: :lol: :lol:
Richy Rich
Postby philpott92 » Fri Aug 31, 2007 8:20 pm
good job :D :!:
philpott92
Postby AlanN » Fri Aug 31, 2007 8:29 pm
I did have a little chuckle when I saw the last photos, darn cute...
Well done, :shock: 8) 8)
PS I'd fit a sliding window in the door :lol: :lol: :lol:
Postby Luke » Fri Aug 31, 2007 10:20 pm
missed this therad before, what a neat job 8) well done :D
but what use are the small horses do kid ride on them or are they just for show - like big dogs :lol:
Postby WildGoose » Fri Aug 31, 2007 10:48 pm
for those parents who insist on making their 3 years olds ride and such, yes the small ones can be used for riding I believe. The black one in the front stall is a minature shetland, he would happily support the weight of a small child
The white one is what is called a minature horse, and they are just for show. You get judged on how well they handle, behave, how good their form is etc. I dont pretend to understand the ins and outs, my OH could probably give you the low down. :lol:
We have a couple of full size ones, and the main reason for the little ones was to keep the big ones company, whilst one is out riding etc. Some tend to lose their head a bit if left on their own for too long, so this way no one is ever left on their own, and the little ones are cheaper to keep :wink:
Thanks for all the comments peeps, its great to read :)
WildGoose
Postby AlanN » Sat Sep 01, 2007 12:00 am
Sorry, I have just noticed that their bums arent quite high enough for the sliding window...
...But, will be good ventilation all the same :lol: :lol: :lol: :wink:
