Ford Transit AWD PIDs
Postby VxO » Thu Jul 25, 2024 1:16 pm
Good evening,
I should monitor the AWD system of a Transit 2.0l produced in 2018.
I can't find dedicated PIDs. Does anyone know if there are any?
It would help me to at least know the front differential oil temperature.
Thank you very much for helping! :)
Ford Transit MK8 2.0 170HP AWD Campervan
Ford Ranger 3.2 200HP Auto Wildtrack
VxO
Re: Ford Transit AWD PIDs
Postby knobby1 » Thu Jul 25, 2024 10:21 pm
VxO wrote:Good evening,
I'm not sure they even have diff oil temp sensors.
Postby VxO » Fri Jul 26, 2024 7:43 am
Near the solenoid there is a bulb that appears to be a sensor (see attached photo).
I need to monitor it via OBDII. :)
VxO
Postby knobby1 » Fri Jul 26, 2024 9:46 pm
VxO wrote:Near the solenoid there is a bulb that appears to be a sensor (see attached photo).
Looks like a pressure sensor...but yes, there should be info for it somewhere within Forscan one would think.
Postby VxO » Sat Jul 27, 2024 9:57 pm
Unfortunately I can't find the right PID.
Does anyone know if there is a way to deduce this?
Maybe by disconnecting the sensor, and inducing an error, with Forscan I could understand something more.
Thank you.
VxO
Postby knobby1 » Sun Jul 28, 2024 8:30 pm
VxO wrote:Unfortunately I can't find the right PID.
Thank you.
AWD's are quite rare and not many on here have them....so not much info about them to be had.
Postby Blizz » Mon Jul 29, 2024 9:48 am
Probably that is not a temp sensor but a switch so the ECU knows when is the front diff engaged...
Blizz
Postby VxO » Wed Jul 31, 2024 7:29 am
I don't know if it's a sensor or a switch.
In any case, if I disconnect it, the fault and unavailability of the AWD system are indicated on the dashboard display. Unfortunately I can't intercept any DTCs using Forscan and Obdlink.
Can anyone tell me how to find the DTC or any sensor reference with Forscan?
Thank you. :)
VxO
Postby knobby1 » Wed Jul 31, 2024 8:57 pm
VxO wrote:I don't know if it's a sensor or a switch.
Thank you. :)
It may not even exist in Forscan...Forscan caters many doezens of different vehicles and to cater for all vehicles is a mammoth job for a free software....especially for a small amount of AWB Transits. Send Forscan themselves an email asking the question on their forum.
https://forscan.org/forum/
