Help with power steering
Postby Transittrouble » Sat Jul 20, 2024 2:51 pm
I have a ford transit 85 t280m fwd euro 4
I have damaged the power steering pipe at front off my van
Looking for advice as to whether or not it will need replacing or if there maybe a quick fix
Advuce appreciated
Transittrouble
Re: Help with power steering
Postby metalworker0 » Sat Jul 20, 2024 3:06 pm
looking at the corrosion on it ..and probably severe inside the support bracket ..i would say yes, it needs replacing.
Postby andz327 » Sat Jul 20, 2024 4:29 pm
Can't remember if the pipe 8mm or 10mm you can cut through the pipe and put this type of straight (8mm or 10mm)plumbing fitting in but like metalwonker mentioned it looks rotten, think that's the low pressure side so you maybe get away with rubber fuel pipe of appropriate bore and a couple of decent hose clipsImage
andz327
Postby andz327 » Sat Jul 20, 2024 10:14 pm
Had another look and it's the high pressure pipe so heat shrink would burst and fuel hose and hose clamps wouldn't do either as there's to much pressure
Plumbing joint straight coupler in picture or change pipe am afraid mate,
Where do you live
I think I might have a good 2nd hand one
andz327
Postby Transittrouble » Sun Jul 21, 2024 10:51 am
I stay in perth mate
Thanks for advice,msg regarding 2nd hand one
Transittrouble
Postby JackKingsworth » Mon Jul 22, 2024 2:37 pm
Transittrouble wrote:I have a ford transit 85 t280m fwd euro 4
Advuce appreciated
Hi,
If the power steering pipe on your Ford Transit 85 T280M FWD Euro 4 is damaged, it is generally recommended to replace it rather than attempt a quick fix. Power steering systems operate under high pressure, and a compromised pipe can lead to leaks, loss of steering assistance, and potential safety hazards. While temporary repairs might be possible with sealants or tape, they are not reliable or safe in the long term. It is best to consult a mechanic and have the damaged pipe replaced to ensure the system's integrity and your safety.
Jack ;)
JackKingsworth
Postby andz327 » Mon Jul 29, 2024 10:38 am
Transittrouble wrote:I stay in perth mate
So the old brass fitting has done its job again nice one
andz327
