Breakdown
Breakdown
Postby mayon » Thu Jul 25, 2024 9:01 am
I have been away for a few days in my Transit van 2.5 turbo with Bosch pump, cruising down the highway here in Queensland when I pulled into a coastal town the engine lost power. When I loosen the injectors there is some fuel coming through but I don't think it is enough for it to start, fuel filter is full and fuel gauge says half. Any ideas? Thanks.
mayon
Re: Breakdown
Postby Altransit » Thu Jul 25, 2024 9:19 am
Check the timing belt :idea:
Re: Breakdown
Postby mayon » Thu Jul 25, 2024 10:10 am
What would be the easiest way to check the timing belt. Thanks.
mayon
Re: Breakdown
Postby mayon » Tue Jul 30, 2024 2:32 am
I had the van towed home, checked the timing belt and all the pins lined up. It seemed to have a bit of a blockage in the fuel line just before the lift pump which I cleared. Spent hours trying to bleed the air out at the injectors, seems to have a good spurt of diesel but won't kick over. Any suggestions thanks.
mayon
Re: Breakdown
Postby gotgcoalman » Tue Jul 30, 2024 3:12 pm
A few squirts of spray release fluid,brake cleaner or similar (easy start) when turning over usually pulls the fuel through and gets the motor running "under it's own steam"
Too bloody quiet :shock:
gotgcoalman
Re: Breakdown
Postby mayon » Wed Jul 31, 2024 7:59 am
Thanks for the reply, It kicks over with a shot of Aerostart but won't run by itself. It seems like there is not enough pressure to open the injectors. Thinking of taking the pump off and having it tested in a workshop.
mayon
Re: Breakdown
Postby dumper » Wed Jul 31, 2024 9:16 am
Remove the stop selanoid if the pump is breaking up inside and bits are jamming it up but before you do that check your getting power to it if you pull the terminal off and touch it back you should hear it click.
Re: Breakdown
Postby mayon » Thu Aug 01, 2024 9:10 pm
I got my van going, it was something as simple as the wire to the fuel solenoid had broken off. I hadn't considered this because fuel was still getting through to the injectors. Thanks to Dumper for pointing me in the right direction.
mayon
Re: Breakdown
Postby dumper » Fri Aug 02, 2024 6:10 am
Glad it worked :D
