Broken roller bearing?
Postby cledthehead » Fri Aug 30, 2024 7:50 am
Ford Transit 2.2tdci 2013 Euro 5.
Removed the timing chain cover to reseal due to small oil leak and these tiny bits of metal that look as if they were part of a roller bearing fell out. Anyone have any idea what they are and where
they came from?
cledthehead
Re: Broken roller bearing?
Postby knobby1 » Fri Aug 30, 2024 9:24 am
they came from?
They look like they may be rollers from a rocker cam follower roller wheel....I'd be popping the rocker cover off to check just in case.
Postby cledthehead » Fri Aug 30, 2024 10:22 am
Thanks Knobby, I will do that and let you know.
cledthehead
