Advice Need Group
Advice Need Group
Postby VG1997 » Sun Oct 27, 2024 5:20 pm
OK Timming belt slipped on Crankshaft.
Caused by fan Belt getting rapped in between the crank pulley.
OK I remove broken fan Belt .set Timming
Back up . Pin Crankshaft pump & camshaft.
Ohhh buy way this is a 2.5 turbo diesel van.
But now it missing bad.
Question is . Is it just bend push rods .
Would values have hit pistons???
Anyone with knowledge on these engines.
Be much appreciated
VG1997
Re: Advice Need Group
Postby dumper » Sun Oct 27, 2024 8:35 pm
The valves do hit the piston but they usually bend push rods the most I’ve had is 3 and one snapped a rocker arm that’s the most damage I’ve had never had to take a head off , remove the rocker cover and have a look some on here have straightened the push rods with no problems after.
Postby VG1997 » Mon Oct 28, 2024 5:30 am
OK thank for your Advice & knowledge.
I will remove rocket cover. In next few days & inspect.
Of what damage I've done . I'll also reply of what's happened too.
VG1997
Postby gotgcoalman » Tue Oct 29, 2024 6:52 pm
Worst one I've had over the years was 5 bent push rods and 2 bust rockers.
I've got a spare set of push rods and some spare rockers "just incase"
Too bloody quiet :shock:
gotgcoalman
