Resetting adblue system malfunction message
Postby mudmane » Tue Jan 18, 2022 10:13 pm
The van: 2016 Transit custom 2.0 eco blue 130ps 110,000 miles
Hello all
I had the adblue system malfunction message come on the dash this weekend when on the motorway. Having plugged it into forscan i had the DTC P20EE SCR NOx catalyst efficiency below threshold.
Having reset the codes and going for a few drives the van isn't flashing up any DTC's but the adblue malfunction message remains on the dash with 400 miles until it won't start.
Is there a way to reset this through forscan or does it have to go to the dealership?
My turbo sh*t itself very recently and chucked loads of oil down the exhaust. Now I'm wondering if this is related.
thanks in advance
mudmane
Re: Resetting adblue system malfunction message
Postby Fannyd69 » Thu Apr 11, 2024 2:12 pm
I've got same problem, did you get it fixed?
Fannyd69
Postby llyw86 » Fri Nov 08, 2024 10:26 pm
Hi I have had exactly the same issue I know have this error after turbo had gone. Did you find a solution to the ad blue malfunction or what it was? I’m thinking the same regarding all the oil that has gone down exhaust
llyw86
Postby metalworker0 » Fri Nov 08, 2024 11:54 pm
Probably has various sensors and injectors contaminated.
i would say your prime culprits are:-
You have this one the nox sensor
https://www.ebay.co.uk/itm/235263218057?
measuring the result of the add blue injector this one
https://www.ebay.co.uk/itm/315931342258?
its not going to be easy ..requiring specialist tools
Think you are going to need a special spanner to get them out ,, because they have been in a hot rusting exhaust...any other will round it off ..
would i think they would look like a brake line spanner or like a lambda socket.
or see the ..highly recommended O'Rileys Autos
https://www.youtube.com/@ORileysAutos
on youtube ..he may show you tips and tricks, nothing he cant fix , and specialises in transit exhaust and emission problems
Postby llyw86 » Sun Nov 10, 2024 11:57 pm
Hi
Thank you for your reply, this does all sound like it could be the problem. I am going to have to get it back into the garage and hope they can sort it.
Much appreciate you taking the time to reply.
Llyw
llyw86
Postby mannanj » Mon Jan 06, 2025 6:42 pm
Did you get to the bottom of this? I've got the exact same issue after a turbo failure too
mannanj
Postby Dan.mannix » Thu May 22, 2025 8:58 am
Hi all. Got a 2017 transit that has exactly the same fault as many others in this post after turbo failure. Did anyone ever get to the bottom of the fault? Many Thanks Dan
Dan.mannix
Return to Transit Custom
