2018 2.0L EcoBlue Starting Issue
Postby thebrownyfamily » Wed Dec 11, 2024 11:11 pm
I really need help I'm begging lol
THIS IS THE VAN NO ONE CAN FIX. FORD NOPE, INDEPENDANTS NOPE, DIESEL SPECIALISTS NOPE.
Over 5k in parts and 5k in labour after changing
LPP
HPP
HEAD
4 X INJECTORS
FUEL LINES
GLOW PLUGS
GLOW PLUG RELAY
CAM AND CRANK SENSORS
NEW BATTERY/STARTER/ALTERNATOR
And still the same, after its been left not running for 1-2 days its a nightmare to start as soon as it starts it will run all day perfectly starting every time
what make it hard is there NO fault codes all the 4/5 different computer think is fine.
What I've found with a Noid light is all the time its wont start there no light or a very dim light, when it does start firing or runs then the Noid light start flashing and working brightly.
the Noid light tells me the injectors are opening to firer fuel hence the starting issues, but what is causing this to play around and how can i fix it of over ride it?
what components does the Noid light rely on to work so I can check them all?
~I really really would appreciate help on this one this as been going on 10months :-(
thebrownyfamily
thebrownyfamily
Re: 2018 2.0L EcoBlue Starting Issue
Postby metalworker0 » Thu Dec 12, 2024 12:07 am
A lot of power goes to the starter motor when turning it over ..perhaps that is why the noid light is dim..so maybe normal...if not i would start looking at the grounds related to the fuel injection system.
to find out where they are you need the manual
think its here
https://www.mediafire.com/file/nrc1mse4 ... 2.zip/file
bemm manual
https://www.manualslib.com/download/155 ... 16-75.html
All the best.mark
Postby metalworker0 » Thu Dec 12, 2024 12:29 am
wrong manual links ..i posted the custom ones
Looking for the mk8 - back soon
only BEMM available or 2.2
bemm
the custom ecoblue one in the last post may be sufficient enough ..i dont know
Postby thebrownyfamily » Thu Dec 12, 2024 12:35 am
NEW STARTER, GROUND CHECK, AND NO RESISTANCE. 0.00OMHS ON ALL, SO THIS IS THE ISSUSE THE FUEL SET UP IS VERY COMPLICATED ON THEIS VEHICLE, i WISH THE WAS SO INFOR THEY SHOWED ME HOW IT WORKS AND WHAT THE INJECTION NEED TO AUCTALLY OPEN AND FIRE
thebrownyfamily
Postby thebrownyfamily » Thu Dec 12, 2024 12:36 am
ALSO THE NOID LIGHT ARE MAINLY NOT EVEN FLASHING
thebrownyfamily
Postby metalworker0 » Thu Dec 12, 2024 1:42 pm
The ground check that was done, may only have been done on the starter and battery ...I'm just trying to give you the easy options, that, if done by yourself, will cost you nothing.
You can keep going to these garages, some of which just plug in the scanner ...and it will come up with multiple items that are faulty ..when it all may be down to grounds..and they have replaced lots of stuff that possibly does not need replacing ..they call it the "parts cannon"
BTW - what's the mileage. because anytime after 60,000 it needs a new wetbelt which is not going to be cheap.
alln the best.mark
Postby metalworker0 » Thu Dec 12, 2024 3:33 pm
All ground points are shown in the BEMM pages from 219 to 226
Postby thebrownyfamily » Sun Dec 15, 2024 10:59 pm
all checked aLL PERFECT
thebrownyfamily
Postby thebrownyfamily » Sun Dec 15, 2024 11:01 pm
HAD NEW WET BELT WHEN REPALCING THE BELT, 100K
thebrownyfamily
Postby Csubcsi » Thu Jul 24, 2025 9:14 pm
Hi,
Can you help me? It seems, I have a same problem in a Transit EcoBlue engine.
After 1-2 days it is not starts, but sometimes after 1week everything fine, starts as usual when everything normal.
Can you tell me what was the solution of the problem?
I have changed a battery, EGR valve, checked starter engine. The next step is fuel system, but if I check it via computers, everything is good. Pressures, synchronisation, signs, and no DTC.
Thanks If you can give me some information.
Csaba
Csubcsi
Postby Csubcsi » Thu Jul 31, 2025 9:09 pm
Hi,
It seems I have a same promlem in a Transit.
Can you help me, what was the solution?
Csubcsi
Postby knobby1 » Tue Aug 12, 2025 8:20 pm
Csubcsi wrote:Hi,
He hasn't been back here since Dec last year, so we may never know. Unless he gets notifications he probably won't return.
cron
