JRHartley wrote:Just picked up a nice mk6 2004 Transit 2.4td, when cold it will fire straight up & run for 2-3 mins, then dies, it will fire up again then it will die, the more times you start it the less time it will run for. I will fit an early one wire pump but until then is it a sensor etc? thank you
JRHartley wrote:Not been able to check yet.Will a general Reader work on this or does it have to be a fancy Ford unit? thanks
JRHartley wrote:Having talked to the previous owner Ive replaced the fuel filter as its not been done for a very long time.
The filter when fitted as per instructions does not lock into place, as in it can still be pulled down wards & removed. Are these filter heads a problem?
Maybe buy a filter head with primer pump, or should I replace with a Ford head? thanks
JRHartley wrote:yeah the filter matches the old one & looks to spec',I used a mirror to check the internal lugs, just looks a bit cheap to me, Why the hell would Ford fit a filter head that can not prime the system.
JRHartley wrote:If you run out of fuel or have a leak, it will need some kind of pump to get the fuel back up to the filter head though, didn't early Transits have a lift pump? I quess the bean counters scrubbed that one out.
JRHartley wrote: didn't early Transits have a lift pump? I quess the bean counters scrubbed that one out.
