Remanufactured Injectors?
Postby hi_tower » Thu Dec 26, 2024 7:15 pm
I’ve been occasionally getting a fault code pop up on my 2018 custom for no2 injector which sends the van into limp mode for a few seconds and then everything returns to normal. I suspect this injector may require replacement soon.
I’ve been looking around at the price of injectors and a new one is coming in around the £200 mark or I’ve seen remanufactured as cheap as £250 for 4. This does seem a little too good to be true. Has anyone had any experience of remanufactured injectors? Are they worth considering?
hi_tower
Re: Remanufactured Injectors?
Postby hi_tower » Thu Dec 26, 2024 7:16 pm
hi_tower
Postby andz327 » Fri Dec 27, 2024 2:09 am
Always better with new, given the delicate nature of these engines you don't want any injector problems that's for sure, it would be new ones for me
andz327
Postby DanMK7uk » Thu Jan 02, 2025 4:49 pm
Agreed, a pal of mine went recon injrs and ended up with a fooked engine. Go new if can afford. At a very minimum do a leak down after.
DanMK7uk
