Gearbox 88VT
Gearbox 88VT
Postby FDN850HU » Sat Jan 11, 2025 1:47 pm
Dear members, i would like to be sure whether i have a mt75 gearbox or not. Its a 96 2.5di bus, and 88vt is written on the housing. I presume it is indeed a mt75 since i have 5 gears and its manual. Could you please help me out? If so, the quantity of 1.25 litres is still valid? (Although filled till fill hole is flush with the oil) . Many thanks!
FDN850HU
Re: Gearbox 88VT
Postby FDN850HU » Sun Jan 12, 2025 10:01 am
My local Ford shop told me to use this. Will this be good for my gearbox? Thanks. It says Ford wss m2c200 d2. Many thanks, i am confused a bit. Cheers
FDN850HU
Re: Gearbox 88VT
Postby Altransit » Sun Jan 12, 2025 10:59 am
I was hoping that someone more knowledgeable would answer, but I can tell you that you do have an MT75 gearbox, I don't know the capacity except that you fill it until oil comes back out of the filler plug hole.
The correct oil is actually called 'MT75 oil', but I don't know if what you have there is a valid substitute :?
Hopefully, someone else will chip in with an answer :mrgreen:
Re: Gearbox 88VT
Postby metalworker0 » Sun Jan 12, 2025 3:44 pm
in the picture above of the oil bottle - it has GL4 on it which is a step in the right direction, GL5 is to be avoided as it dissolves and damages yellow metal ..which your box contains.
lots of searches on google containing the words 88vt and mt75 ...bring them up together as one and the same .
according to a search on the comma oil site this is the one as recommended for: Transit 2.5 Di (1995-1998)
https://app.commaoil.com/commercial-veh ... /view/550#
which isnt a strait oil as first recommended to you above in the pic of oil bottle -- this is MVMTF Plus 75W-90
This is a multigrade gear-oil .indicated by the two numbers 75w90..will will be a a different thickness according to temperature, that helps save wear on the gearbox -- also fully synthetic ..which is also a plus.
Re: Gearbox 88VT
Postby Chug » Sun Jan 12, 2025 4:13 pm
I think proper mt75 oil is 75w80 just search for MT75 gearbox oil
Chug
Re: Gearbox 88VT
Postby MinorMatt » Mon Jan 13, 2025 1:27 pm
Definately an MT75
The MVMTF plus is Comma's "new" oil that covers multiple gearboxes and can be used.
Here is a couple of the correct MT75 Oils
https://www.ebay.co.uk/itm/334453825002 ... BM3ryM-otl
https://www.ebay.co.uk/itm/185901965444 ... BM3ryM-otl
and yes you will want about 1.25L
Re: Gearbox 88VT
Postby FDN850HU » Tue Jan 14, 2025 11:38 am
Thanks to all of you!
FDN850HU
Re: Gearbox 88VT
Postby FDN850HU » Sat Mar 29, 2025 8:11 pm
Refresh - filled up 21829 febi and it works fine, smoother than before. Old was dark and originally red i guess. Febi 21829 is yellow in colour. Although gonna try ravenöl 75w90 since they mention mt75 in the description. Cheers
FDN850HU
Re: Gearbox 88VT
Postby FDN850HU » Sun Aug 31, 2025 1:30 pm
Just a note added to gearbox oil question, ravenöl oil did not work as good as i wanted, now my gearbox has kroon sp 1031 in it, this is red in colour (other two were yellow) and looks thinner as well, it shifts way much smoother now like it should in my opinion. This kroon sp1031 is especially for mt75 gears.
FDN850HU
