New problem. Looking for advice.
Postby Havoc99 » Wed Dec 11, 2024 5:35 pm
Transit minibus Mrk 7 2009
Van is driving fine.
I stop & remove key from ignition.
A few moments later.
Put key in ignition.
All dash lights are working correctly.
Turn key & all dash lights go dim.
Engine turns over but will not start.
Remove key.
Wait 5 minutes
Try again & everything works perfectly.
Any idea guys ?
Merry Christmas & thanks for any advice in advance.
Havoc99
Re: New problem. Looking for advice.
Postby andz327 » Wed Dec 11, 2024 7:12 pm
Ignition switch behind the barrel, cheap to replace and easy to change, common for causing weird electrical problems, but could be bad relay or bad earth connection at a relay etc but I'd be trying switch first
andz327
Postby Havoc99 » Wed Dec 11, 2024 8:20 pm
Thanks andz....... Gives me something to work on.
Havoc99
Postby Havoc99 » Thu Dec 12, 2024 12:56 pm
Have a double battery underneath the drivers seat on my minibus. Had a good look this morning & all 4 main connections to the batteries looks ok. Have ordered a new switch. Will update once fitter. Cheers
Havoc99
Postby knobby1 » Thu Dec 12, 2024 8:40 pm
Havoc99 wrote:Have a double battery underneath the drivers seat on my minibus. Had a good look this morning & all 4 main connections to the batteries looks ok. Have ordered a new switch. Will update once fitter. Cheers
Are the batteries themselves ok..?? Have you load tested them..?? Front one usually fails first and causes all sorts of electrical gremlins.
Postby Havoc99 » Wed Jan 15, 2025 2:01 pm
Problem fixed. New switch under the barrel did the job.
Thanks all for the help & advice.
Great forum, long may it last.
Havoc99
Postby DanMK7uk » Wed Jan 15, 2025 8:11 pm
Excellent
DanMK7uk
Postby andz327 » Sun Jan 19, 2025 2:58 am
Havoc99 wrote:Problem fixed. New switch under the barrel did the job.
Good man
andz327
