Loots Asbo 130ps
Re: Loots Asbo 130ps
Postby Altransit » Sat Mar 13, 2021 3:36 pm
ned wrote:Has the Glasgow turbo, brum brum see you Jimmy oche aye get ooot the way
It can be hard to pick out the useful stuff from Loots ramblings :lol:
loot wrote:But i fitted the new turbo from mr Andz which was like new compared to mine.
Postby ned » Sat Mar 13, 2021 3:44 pm
:lol: :lol: Good point, I was actually wondering if as I has quit smoking now.
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby andz327 » Sat Mar 13, 2021 8:00 pm
loot wrote:Now then, will it fit
Naw thats a rwd unit
Should look like this
Sent from my LG-H870 using Tapatalk
andz327
Postby andz327 » Sat Mar 13, 2021 8:10 pm
Whats all them tools for and why did you take the heater blower intake off , 4 exhaust bolts , 3 manifold bolts, oil pipes bolts and its off, knew i should've dropped it off personally and I'd swaped it when your were in making the coffee
andz327
Postby andz327 » Sat Mar 13, 2021 8:16 pm
bambi mk 1 wrote:
loot wrote:So I think I need this 1
https://www.ebay.co.uk/itm/363035339933
You know thats a fwd cooler Loot don't you :wink:
His van is fwd
andz327
Postby loot » Sat Mar 13, 2021 8:27 pm
Well I've fitted the turbo, there's a bit of smoke when I floor it and there's no boost, I still have an engine warning light on but my quick code reader is in the combo.
I will get ids going and see. 1 thing I will say is that turbo I sent back went like fook. But I have the actuator from it.
Only went to the skip in it so I'll clear code's and get it hot maybe it is clogged from running without the turbo boost.
The turbo is in good nick though so not sure
07 350 170ps
Ids map here
loot
Postby loot » Tue Jan 30, 2024 12:43 am
Van is now tested for another year. They charged 45 quid then said it was class 7 so next year will be 5 quid.
I had to pay for another test.
So it failed on imbalance/ handbrake on drivers side not as good as left side. I bought a new caliper which didn't fix the problem. So having tried various things I decided that the left handbrake was too good. But I swapped both rear calipers complete from forskin and it passed.
07 350 170ps
Ids map here
loot
Postby loot » Tue Jan 14, 2025 2:27 pm
Asbo went for mot and passed :P
Drinks all round 8)
07 350 170ps
Ids map here
loot
Postby Altransit » Tue Jan 14, 2025 5:33 pm
Result 8)
Postby loot » Tue Jan 14, 2025 7:44 pm
Altransit wrote:Result 8)
Yep I thought it might have had rust or the poor back brakes like last year but nope, strange thing though I'm sure there was £20 in the ash tray :? :lol:
07 350 170ps
Ids map here
loot
Postby Altransit » Fri Jan 17, 2025 1:33 pm
Mine is not going in until the weather is warmer :oops: :mrgreen:
Postby loot » Fri Jan 17, 2025 8:06 pm
Altransit wrote:Mine is not going in until the weather is warmer :oops: :mrgreen:
Sensible, I would suggest mot around may which means it'll be nicer to work on it :P
I'll do that to the new van
07 350 170ps
Ids map here
loot
Postby Altransit » Sat Jan 18, 2025 12:58 am
Yes it was May, until Covid year, when they gave us 6 months grace period, which pushed it to November! It has scraped through every year since, until this year when the injector seals needed doing.
I've done those now, but I fear that rust may now be the issue :(
Postby loot » Sat Jan 18, 2025 1:15 pm
Altransit wrote:Yes it was May, until Covid year, when they gave us 6 months grace period, which pushed it to November! It has scraped through every year since, until this year when the injector seals needed doing.
You'll need a full evaluation of underneath, I've learned that the outer panels can be replaced complete,there's a few that will need plates like the rear bumper beam area, the front of the rear arches and certain box sections.
The inner arches and outer arches and and wings and steps/sills etc. Can be purchased. But the bit you can't buy is the non drivers side inner sill panel. But you can buy a sill with maybe an inch or 2 inner panel as part of it.
That said. You also have the option of deciding if it is more or less solid underneath then blast it inside and out with rust remedy and then blast it with under body gloop. Then address the brake pipes.
And again every year. As long as the chassis and anchorage points are solid then it'll be safe for daily use.
Asbo was blasted with thick rock hard bitumen stuff so I really have no idea what it's like underneath but it feels solid so I'm not questioning it yet :D
07 350 170ps
Ids map here
loot
Postby Altransit » Sat Jan 18, 2025 4:14 pm
:lol: I know the theory, but my days of welding underneath vehicles are long over, and they all charge proper money for doing those things around here. It cost me five hundred quid just to get the drivers step replaced a couple of years back, so if it fails on anything major, I'll have gained a bigger shed for the driveway :P
