Ford transit mk7 inner rear arch
Re: Ford transit mk7 inner rear arch
Postby T350camper » Sat Feb 15, 2025 12:08 pm
I picked it up fairly quickly, having no previous experience with welding. It is strong enough (if you get it right) with good penetration. I liked the fact that it is gas-less as I'm only going to use it for my own DIY jobs. If it were a garage then the better gas welders would make sense. Welding thick metal is actually quite easy and you can run a seam weld with just a bit of practice. Thin metal takes much more concentration. It is very easy to blow through the metal. I'm repairing my 1981 Datsun right now...they were made of tissue paper to start with and 45 years of English weather hasn't helped :? Lots of short tack welds gradually becoming linked up and ground back. Also, the welding masks they sell for quite a reasonable amount are very good and react instantly to the arc, going clear as soon as you stop...so you can see what you're doing.
Make sure you have clean metal with all paint ground off. Check you're not setting fire to anything and have an extinguisher to hand. Play around with some scrap first until you get used to the settings and wire speed. This welder is an entry level model and there are much better ones out there...but it works for me.
2006 Mk6 T330 135bhp 2.4TDCI
T350camper
Postby DanMK7uk » Sat Feb 15, 2025 2:26 pm
Sounds good.
DanMK7uk
Postby audvaldid » Sat Feb 15, 2025 2:38 pm
Hi guys, I am quite a comfortable welder. Worked in a machine shop for a year. Thanks for the tips but sadly they don't send those arches to Iceland. As I have no real access to a garage it would have been the best option. But you have to do with what you got. Removed the arch and cut bits of it of. I removed it so I could clean most of the rust. It had some rust between the arches behind the gravel/bed liner protection. Just started tacking it back together.
audvaldid
Postby metalworker0 » Sat Feb 15, 2025 2:49 pm
You are doing very well, better than most, you've drilled the spot welds out and in my opinion doing a first class job - especially if it's outside ..don't know what the temperatures are there, probably in the minuses, so doing it in aggravated circumstances. well done !
Postby audvaldid » Sat Feb 15, 2025 3:05 pm
andz327 wrote:Leaks through the seams eventually then there's condensation issues under the plywood edges where all the crap gatherers and stays wet , rear inner arch section where it attaches to the outer arch is another area that needs cleaned and treated, and waxoiled
Mine had MDF in the bottom. It had swollen alot from the water. Nothing good comes from that. Needs I think better protection at the seams with sealant.
audvaldid
Postby audvaldid » Sat Feb 15, 2025 3:06 pm
metalworker0 wrote:You are doing very well, better than most, you've drilled the spot welds out and in my opinion doing a first class job - especially if it's outside ..don't know what the temperatures are there, probably in the minuses, so doing it in aggravated circumstances. well done !
Thanks for the compliment.
Ari
audvaldid
Postby audvaldid » Fri Apr 11, 2025 4:22 pm
Hi guys. I have an update if anyone is interested.
Finished welding it, cleaned the floor and repainted.
Next step is the new floor.
audvaldid
Postby metalworker0 » Fri Apr 11, 2025 6:39 pm
Good job, looks great, well done !
Postby T350camper » Fri Apr 11, 2025 9:15 pm
Beautiful job! Well done 8)
T350camper
