l200lc2 wrote:forscan says is definitely a 2.4 so i must have got that bit wrong but ebay lists loads of different variants for rwd engines.
how can i confirm i have the correct wiring harness?
cheers lee
I think microfiche went out well before these vans were even in production.l200lc2 wrote:I didn't know if somebody had access to a microfiche that could look it up with my vin number
Last microfiche I used was as an apprentice and finished at that place in 96.knobby1 wrote:l200lc2 wrote:I didn't know if somebody had access to a microfiche that could look it up with my vin number
Microfiche..?? Isn't that a 1950's - 1960's thing..??
l200lc2 wrote:https://www.dropbox.com/scl/fi/9u0ht8uvvcthvt5ceg3rt/20250408_171202.jpg?rlkey=4izal3h3pi8veql1hx32m2a29&st=a9lt9f7w&dl=0
https://www.dropbox.com/scl/fi/thnvg215 ... st=vycob3z
3&dl=0
https://www.dropbox.com/scl/fi/xmh019a1 ... ikzv2&dl=0
https://www.dropbox.com/scl/fi/hgn9jcu7 ... oi4hj&dl=0
https://www.dropbox.com/scl/fi/vekngkik ... 8uw9i&dl=0
https://www.dropbox.com/scl/fi/35zd1bg1 ... 1vzaq&dl=0
https://www.dropbox.com/scl/fi/l7y5mes0 ... cq2jr&dl=0
The fuse box doesn't have the wiring to the fuse box for the heater relay for the dpf filter but a dpf is fitted.
vansit1 wrote:what is wrong with the wiring or does the relay click when you turn the ign on?
Users browsing this forum: T350camper
