Transit 2012 2.2 RWD TDCi, pistons hitting valves
Re: Transit 2012 2.2 RWD TDCi, pistons hitting valves
Postby SamFin » Tue Mar 25, 2025 8:31 am
Radiofence wrote:A friend of mine was convinced he had the flywheel locked in the correct hole, he wasn't using the proper tool (that has a fitting nipple which let's it drop further than a bar would. He destroyed his head.
Tervetuloa
I am also destroying my head with this one.
SamFin
Postby Radiofence » Tue Mar 25, 2025 10:47 am
Todella hauska.
A 10mm won't help you. The 10mm pin will fit in them all from memory- the special position has a smaller hole that the pin drops into.
Transit custom 2.2
Radiofence
Postby Radiofence » Tue Mar 25, 2025 10:50 am
Maybe remove the starter and look inside to spot the hole. It's definitely not 10mm. More like 5/6mm
Transit custom 2.2
Radiofence
Postby Radiofence » Tue Mar 25, 2025 11:09 am
See the smaller diameter nipple
Transit custom 2.2
Radiofence
Postby knobby1 » Tue Mar 25, 2025 9:40 pm
SamFin wrote:Lord Knobby, I cannot get the picture from flywheel end as engine is mounted in place and I would not like to detach it. Yes, clutch and flywheel changed! What I remember, there were some sort of alignment pin or something and what I remember it was not possible to align it wrongly. Only one position possible.
I meant a photo of the front of the crankshaft, pulley end....so we can see the "torx" bolt position when the flywheel is pinned. The flywheel itself can only go in one position on the crankshft as the bolts aren't equidistant.
Postby SamFin » Fri Mar 28, 2025 5:50 pm
Thank you all for keeping me with the timing. That was the problem! I simply did some clear mistake previous time with that one, I have some doubts what but cannot be sure. Now its working! Pin hole in the flywheel was aligned properly with the sensor hole at this time and so on. By the way, taking picture from the flywheel sensor hole is a working solution. That way it is relatively easy to see the pin hole is there.
But I also did another mistake! I forgot to connect the common rail pressure sensor wiring plug! And the sound what engine makes when it is not connected is awful. It sounds like everything is broken very badly inside the engine! So, if you would have very weird, mechanical sounding issues coming from the engine, it could be common rail pressure sensor! Sound was awful. Luckily I didn't reassemble too much before I noticed that!
Now this is working quite nicely!
SamFin
Postby Radiofence » Sat Mar 29, 2025 11:12 pm
Awsone - well done persevering. A man with Sisu!
Transit custom 2.2
Radiofence
