Non starting with high fuel pressure
Postby Solowanderer » Tue Mar 18, 2025 8:40 am
Hi everyone, second only post - first was just to say hello.
Transit is a 2004 2.4 tdci rwd.
I was returning home with a ridiculously heavy load of hardwood firewood and had to climb a humongous hill. Was in 2nd gear with high revs and just as I reached the summit she cut out and I got the dreaded winking orange glow plug lamp. That was the last time she ran. Had to get the RACV to tow me home.
DTC’s using Forscan are:
U1262 - SCP data link fault
P0191 - FRP sensor range/performance
Fuel rail pressure is showing a massive 72,000kpa when cranked, compared to a desired 30,000kpa, before slowly going down after cranking - which I’m thinking isn’t good. I shamefully replaced the SCV or FPV (or whatever it’s called) with a naughty corner Chinese copy but still got exactly the same readings. Haven’t done leak off but did take off the return pipe and cranked her over but didly squat came out. She fires on ‘Start ya b*****d’ (it’s written on the can!) but won’t start.
I really am quite attached to the old girl and have nightmares as to what would happen to her if she was sent to China so any help or suggestions would be warmly appreciated.
Solowanderer
Re: Non starting with high fuel pressure
Postby DanMK7uk » Tue Mar 18, 2025 8:51 am
Welcome, Can you confirm the year of the van ? 2004 you say.
DanMK7uk
Postby Solowanderer » Tue Mar 18, 2025 8:52 am
Hi Dan,
Yes I believe it’s a 2004
Thanks for responding
Solowanderer
Postby knobby1 » Tue Mar 18, 2025 8:53 am
Solowanderer wrote:Hi everyone, second only post - first was just to say hello.
The Mk6 TDCi's are well known for having a fragile fuel pump and fuel system in general...Pop the fuel filter off and cut it open....check for metal particles, if so...your pump is done for and has probably take the injectors with it.
Postby DanMK7uk » Tue Mar 18, 2025 8:58 am
Yes, was my first thought to as knobby says.
Unfortunately they are quite common to go.
DanMK7uk
Postby Solowanderer » Tue Mar 18, 2025 8:58 am
Will do, I’m guessing I use a magnet.
Just wondering that when pumps go, can they increase the fuel pressure?
Solowanderer
Postby knobby1 » Tue Mar 18, 2025 10:03 am
Solowanderer wrote:Will do, I’m guessing I use a magnet.
If the metal particles find their way to the metering valve, (SCV for want of a better word), yes, it can indeed cause the valve to stick open causing high fuel pressures.
These metal particles can also find their way to the injectors and cause all sorts of drama.....they can find their way back to the tank via the return lines and contaminate the tank and all the lines too.
Postby Solowanderer » Sun Mar 23, 2025 7:28 am
Well I’ve cut open the fuel filter and no sign of any metal filings. I guess that’s no guarantee that the pump isn’t shot. I’m perplexed as to why I’m still getting such high pressure on crank, especially as I have replaced the control valve on the back of the pump and still get the same readings. I’ve read on the forum that the fuel pressure sensor on the back of the rail almost never is faulty but ordered a new one just in case, as I’m drinking at the Last Hope Hotel.
Solowanderer
Postby knobby1 » Sun Mar 23, 2025 9:25 pm
Solowanderer wrote:Well I’ve cut open the fuel filter and no sign of any metal filings. I guess that’s no guarantee that the pump isn’t shot. I’m perplexed as to why I’m still getting such high pressure on crank, especially as I have replaced the control valve on the back of the pump and still get the same readings. I’ve read on the forum that the fuel pressure sensor on the back of the rail almost never is faulty but ordered a new one just in case, as I’m drinking at the Last Hope Hotel.
Mk6 TDCi doesn't have a "sensor" on the fuel rail..! That's a Mk7 thing.
Was the new control valve a genuine Delphi item or just an ebay special..??
Postby andz327 » Tue Mar 25, 2025 3:53 pm
Chineseium
andz327
Postby Solowanderer » Fri Mar 28, 2025 10:46 am
I’m confused. There is definitely a fuel pressure sensor at the front of the rail, or at least that what I thought it was. It’s 3 pin and from what I understand it’s 5v positive, a negative, and a sender voltage (.5v at no pressure), though I might be very wrong.
Unfortunately the replacement control valve whatever-it’s-called at the back of the pump (which was really hard to replace) is from eBay and cost $70 so I’m assuming it’s not denso.
However, having replaced it, I’m getting identical readings.
I know I’m clutching at straws here and should be using genuine parts, but I’m on a shoestring budget.
Solowanderer
Postby Solowanderer » Fri Mar 28, 2025 10:57 am
Sorry, not denso - I meant Delphi, as in Pytho or this forum ;-)
Solowanderer
Postby Solowanderer » Fri Mar 28, 2025 11:09 am
Chineseium?
The part definitely, as are many.
Wisdom and advice on this forum - infinitely more Greek Oracle.
Solowanderer
Postby knobby1 » Fri Mar 28, 2025 9:58 pm
Solowanderer wrote:I’m confused. There is definitely a fuel pressure sensor at the front of the rail, or at least that what I thought it was. It’s 3 pin and from what I understand it’s 5v positive, a negative, and a sender voltage (.5v at no pressure), though I might be very wrong.
Below is the fuel rail for a Mk6 TDCi, can you show me where the sensor is located..??
https://www.catcar.info/ford/?lang=en&l ... I3Mg%3D%3D
Postby andz327 » Fri Mar 28, 2025 11:48 pm
What is this part that isn't listed ma Laird ??Image
andz327
cron
