Flywheel and clutch replacement van starred then cut out
Postby KSProperties » Sat Apr 05, 2025 11:50 pm
Hi. Just replaced flywheel and clutch on mk7 2.2 fwd 125bhp and one it back together the van started first turn of key then when revved it cut out and now the van won't start no idea why? Any ideas?
KSProperties
Re: Flywheel and clutch replacement van starred then cut out
Postby andz327 » Sun Apr 06, 2025 3:40 am
KSProperties wrote:Hi. Just replaced flywheel and clutch on mk7 2.2 fwd 125bhp and one it back together the van started first turn of key then when revved it cut out and now the van won't start no idea why? Any ideas?
Is your crankshaft sensor fully in and tight
andz327
Postby KSProperties » Sun Apr 06, 2025 10:47 am
Can't understand why it did start and run albeit 5secs then now it won't start.
Cracked open an injector pipe to check diesel there and no air.
Clutch pedal still abit floppy but probably needs bleeding more. Any ideas.
KSProperties
Postby metalworker0 » Sun Apr 06, 2025 1:20 pm
is the engine turning over ..wont start is a bit general ..meaning is the starter motor working.
Postby knobby1 » Sun Apr 06, 2025 8:35 pm
KSProperties wrote:Can't understand why it did start and run albeit 5secs then now it won't start.
Cracking injectors on a TDCi is pointless, the system "thinks" it has a high pressure leak and will disable the injectors and pump metering valve....you may get a dribble of fuel but nothing more ...and certainly not the 300bar required for starting.
What fault codes are you getting..?? Do you have cam/crank sync when cranking.??
Postby knobby1 » Sun Apr 06, 2025 9:59 pm
Postby KSProperties » Sun Apr 06, 2025 10:40 pm
Hi there is no fault codes
KSProperties
Postby knobby1 » Mon Apr 07, 2025 12:41 am
KSProperties wrote:Hi there is no fault codes
What code reader are you using..?? Most can't cope with the Transit protocols etc..
If it cut-out and/or won't start...there should be a fault code stored. You don't have to have a fault light on the dash for it to have fault codes stored.
Postby KSProperties » Sat Apr 12, 2025 7:57 pm
Hi.
Update.
Put a new crankshaft sensor in and can will not start.
With the old sensor it woukd crank and crank until I stopped trying.
With the new sensor it just crankshaft a few times and stops.
The only way the van has been started was to squirt brake cleaner down air intake that made the van start but very rough but it turned itself off after about 5 seconds.
There are puddles of diesel around each injector but I can't say if that was like it before the clutch change.
The van use to start first turn of key before clutch and fly wheel change. And it did start normal the very first time after clutch change but only for 5 seconds. After that refuses to start. (Apart from brake cleaner trick.)
All fuses in both fuse boxes been checked and the reset button at side of inside of glove box been done and also battery disconnected and reconnected.
Really out of ideas.
KSProperties
Postby andz327 » Sun Apr 13, 2025 10:24 am
What code reader /diagnostic computer are you using to check for codes, does it have live data ?
When you say puddles of fuel around inhectors are they leaking or was jut you messing about with them, did you push new crank sensor all the way in?
Is cam and crank signals syncing ?
andz327
Postby KSProperties » Sun Apr 13, 2025 6:53 pm
Hi quick question if someone knows the answer. How close does the tip of the crank sensor needs to be to the flywheel. Thanks
KSProperties
Postby knobby1 » Sun Apr 13, 2025 8:29 pm
KSProperties wrote:Hi quick question if someone knows the answer. How close does the tip of the crank sensor needs to be to the flywheel. Thanks
It gets pushed in till it touches, it will make it's own air gap.
You still haven't told us what code reader you're using or whether you have cam/crank sysnc..?? Do you not read the questions Andz and myself ask..??
Postby KSProperties » Sun Apr 13, 2025 8:51 pm
Sorry guys. I have read your questions. I only haveca cheap reader and it's showing no codes. I have been touch with someone with forscan and hopefully he will will be able to have a scan in the week
KSProperties
Postby knobby1 » Mon Apr 14, 2025 12:39 am
KSProperties wrote:Sorry guys. I have read your questions. I only haveca cheap reader and it's showing no codes. I have been touch with someone with forscan and hopefully he will will be able to have a scan in the week
Get Forscan and do it yourself, cheap readers are essentially useless....if taking to a garage it will cost the best part of 75quid just to plug in...let alone fix anything. Forscan is free and the cable is cheap....and you can do for free it at home...and you'll have it for the life of your van.
Postby KSProperties » Mon Apr 14, 2025 11:15 am
So as the teeth spin it will shave the bottom of sensor off to make the gap? Won't that damage the end of sensor?
KSProperties
