Is your crankshaft sensor fully in and tightKSProperties wrote:Hi. Just replaced flywheel and clutch on mk7 2.2 fwd 125bhp and one it back together the van started first turn of key then when revved it cut out and now the van won't start no idea why? Any ideas?
KSProperties wrote:Can't understand why it did start and run albeit 5secs then now it won't start.
Cracked open an injector pipe to check diesel there and no air.
Clutch pedal still abit floppy but probably needs bleeding more. Any ideas.
KSProperties wrote:Hi there is no fault codes
KSProperties wrote:Hi quick question if someone knows the answer. How close does the tip of the crank sensor needs to be to the flywheel. Thanks
KSProperties wrote:Sorry guys. I have read your questions. I only haveca cheap reader and it's showing no codes. I have been touch with someone with forscan and hopefully he will will be able to have a scan in the week
knobby1 wrote:KSProperties wrote:Hi quick question if someone knows the answer. How close does the tip of the crank sensor needs to be to the flywheel. Thanks
It gets pushed in till it touches, it will make it's own air gap.
You still haven't told us what code reader you're using or whether you have cam/crank sysnc..?? Do you not read the questions Andz and myself ask..??
