metalworker0 wrote:You could do with spray grease on the actuator not wd40
The underboost is often the EGR valve stuck open,
AND - I dont know why but -- reports here that EGR fault sets ABS/ traction control fault U0401
.So EGR - . perhaps carboned up ,,,needs dismantling and clean ?
Or holes in the boost pipe
i know the 2.2 custom has a problem with the boost pipe rubbing on a bolt that causes a hole in it, but that is a fwd...a very small chance may be the same for mk8.
metalworker0 wrote:i don't know what software you are using
if using forscan it would allow actuator test ..egr test etc .. youd then be able to see them move
we still don't know if waste gate is stuck open ..not sure how clutch fault is related to antiilock or underboost
are these a mumbo jumbo that the vans brains heap together ?
Note: when there are lots of faults appearing and all unrelated ..can often be down to a bad battery / bad earths etc
metalworker0 wrote:moving into realms ive never looked into or studied now
you say actuator motorised
i googled G74 actuator
if so does motor and gearbox look like this ... note opened up so you can see inside of it ... motor , pinion, worm drive ... think the green disc is an encoder --- so a bit sophisticated
https://www.turbosacer.com/wp-content/u ... 30-new.jpg
if so ..what's to stop it stripping gears or damaging plastic parts within, if the rod seized up.
also the flap valve / butterfly valve could seize up inside the manifold .
all i say ..if above is what you have anything possible as far as damage is concerned
metalworker0 wrote:just saying when things get as complicated as this .. if you were to take this to an american mech in a garage -- they use a much more systematic approach to this rather than..what they call "throwing the parts cannon at it."
Some have a computer that runs a application called "Alldata"
First it lets you put make and model in, then you put the codes into the computer ..it then brings up hundreds of solutions submitted by real people ..and the top ones are listed first.. from its database.
When trouble shooting there are flow charts to easily take you to problem area... does it do this .. no ..move onto number 20 etc
The mk8 manual does have some of the workings of this ... big but ..the move onto number 20 does not work because its not indexed... because its a copy rather than the real thing ! ..so you have to manually find number 20
NOTE : don't show in browser --- press download
https://drive.google.com/file/d/1Nw1OtK ... view?pli=1
NOTE: these manuals are awful to search through ..and it may take you sometime to search through 3000 plus pages
metalworker0 wrote:This place list it as 2,2
https://www.ecutesting.com/product-cata ... tua6nwg74/
and this place
https://uk.fridayparts.com/turbo-actuat ... uRJxPbsJD_
a search here sees g74 only mentioned in this post
loads of cross referencing on ebay listing g74 the same as g88 and g59 ..but you cant rely on ebay.
as regards finding more info ..
"catcar info " is driving me nuts with "503 Service Temporarily Unavailable" lengthening my searches on the site by sometimes 20 mins or more ..
Mranoncustom wrote:Hi, might be a silly question but im just wondering if you have checked if there is water ingress into your air filter? I'm assuming this rwd has the bypass filter on the top then the air filter inside the housing.
Pretty common to get water into if the diverter on the scuttle panel is either blocked up or not there.
