gsc1ugs wrote:Master cylinder that the big thing or one under pedal?
gsc1ugs wrote:Easy bleed goes on reservoir then pressurised pushing fluid through when nipple on gearbox is opened. That should push any air out the system but it doesn’t last long hence the question, is that the cylinder your on about on gearbox?
Bhorton5357 wrote:Need to get your master cylinder checked. Really common for these to do this when they fail, luckily, they’re quick and easy to change. If it’s bleeding up, the pedal is fine for a while, then it’s causing you problems again, the chance is you’ve got a faulty part somewhere. Changed lots of master cylinders on transits. If you’ve got a 5 speed MT75, the slave cylinder is a bayonet fit, like a lightbulb, so you can pop it out and check it for leaks literally in seconds.
gsc1ugs wrote:Mines 6 speed is this it
gsc1ugs wrote:Ffs - i could be taking gearbox out for nothing, how i get a definitive prognosis ?
