Ford transit mk 8 2015 power steering fluid leak
Postby Minicoopet » Wed Apr 23, 2025 9:15 am
Hi all ,I have a Ford transit mk8 ,yesterday I noticed that power steering fluid leaked into the footwell ,does anyone know if this is a whole steering rack replaceplacement or can I get to the location and replace the seal ( where column goes into rack ) sorry don’t quite know the name of that part
Minicoopet
Re: Ford transit mk 8 2015 power steering fluid leak
Postby metalworker0 » Wed Apr 23, 2025 4:23 pm
Pure guess work this ...as the parts diagrams do not show the rack in relation to the bodywork
i think its spraying the leak somewhere in the vicinity of where the column joins onto it ..and the oil is coming through as a small stream through the aperture the column passes through in the bulkhead
what you have to do ...is put it over ramp, over pit or on axle stands ...clean the spilt oil with a solvent ...paraffin jizzer ..diesel, or cans of brake cleaner etc
Then get someone to turn the steering with engine running, so that you can find observe where the oil is leaking from .
May be a pipe union that needs tightening
it may be a seal
you will not find out until you've performed the above ..
ive searched on ebay ..and cannot find ..seals , overhaul kit or anything approaching a maintenance item other than boot gators or track rods, so any leak that isnt coming from a pipe ....it will be a new rack.
if by shear chance that its same rack as mk6 or 7 ..there are seal kits for them
Postby metalworker0 » Wed Apr 23, 2025 5:55 pm
BTW - if it is power steering fluid it will be red .
this part fits last from column to rack
no clear explanation as to, if it does seal the fluid in or if it is just a dust shield, from searches done
https://www.ebay.co.uk/p/24022926394
3D677A on diagram
http://www.catcar.info/ford/?lang=en&l= ... OCsxMzE%3D
and there are five versions of it
and i don't know what year electric power steering was fitted to them .. if so .....you're onto something else that i don't know about
Postby MinorMatt » Thu Apr 24, 2025 11:32 am
metalworker0 wrote:BTW - if it is power steering fluid it will be red .
Its possible that the newer ones may have CHF for power steering - in which case it would be green!
I don't know if Ford are using it in the newer transits but its becoming more common across the board as it works better at temperature extremes
