Transit MK3 bolts hexagon dimension at the neck manifold
Postby Mauritx » Tue Apr 29, 2025 8:24 pm
As per picture, what are the dimension of these? I lost one..
Mauritx
Re: Transit MK3 bolts hexagon dimension at the neck manifol
Postby metalworker0 » Wed Apr 30, 2025 12:05 pm
You don't mention engine size , petrol, or diesel . year. FWD, RWD
and what's wrong with taking measurements off the other bolts. / STUDS / NUTS
note; because its old, the bolts or studs and nuts, may not be metric..
This is as close to it, as i can get you, on the parts diagrams with the info you provided
http://www.catcar.info/ford/?lang=en&l= ... QtMjAwMCJ9
Postby metalworker0 » Wed Apr 30, 2025 1:53 pm
BTW - if you are talking about the bolts or studs and nuts that hold the down pipe to the manifold .
Then any good tyre and exhaust fitting centre will most likely have them in stock, take the manifold with you .
Ask them to send a tap up each thread to clean it .
note ... don't ask a 16 / 17 year old to do this . look for the most senior experienced guy .
Postby Chug » Wed Apr 30, 2025 10:57 pm
If you mean the air filter bolts then I don't know the dimensions as they are just listed as special screw 6171205
like this
https://www.ebay.co.uk/itm/285684986209
Chug
