Yaw sensor location
Yaw sensor location
Postby morganzola » Sun May 04, 2025 12:07 pm
Hello! I'm looking for the location of the yaw rate sensor on a 2013 Mk7 2.2l ford transit, have been told it was under the driver's seat but took out batterys and it isn't there, then was told.under front step plastics which again I couldn't see it there once removed, I'm at a bit of a loss? All I need to do is swap it for new one to fix traction control as bad batteries killed it but can't find it anywhere any help, diagrams etc or where to look appreciated I'm at a loss of where to look, did download Haynes manual but again wasn't any help with telling me location,
All the best!
morganzola
Re: Yaw sensor location
Postby metalworker0 » Sun May 04, 2025 6:23 pm
Here is one page of the workshop manual, if it comes up - 2006 on
if i was fallowing this instruction it would make no sense to me
but there you go ..that''s all i can find
https://workshop-manuals.com/ford/trans ... te_sensor/
Postby knobby1 » Sun May 04, 2025 10:07 pm
morganzola wrote:Hello! I'm looking for the location of the yaw rate sensor on a 2013 Mk7 2.2l ford transit, have been told it was under the driver's seat but took out batterys and it isn't there, then was told.under front step plastics which again I couldn't see it there once removed, I'm at a bit of a loss? All I need to do is swap it for new one to fix traction control as bad batteries killed it but can't find it anywhere any help, diagrams etc or where to look appreciated I'm at a loss of where to look, did download Haynes manual but again wasn't any help with telling me location,
All the best!
What symptoms are you getting..??
What fault codes are you getting..??
Steering wheel pointing straight ahead..??
T/C is often affected by incorrect tyre size/pressure, ABS sensors not happy. Steering angle sensor can cause issues too.
