Rooz121359 wrote:Hahahah... its defo mk6. The gear stick is long and it comes up from the floor. Is that an indication that its mk6?
The engine is 2.2 by the way.
I've pulled everything apart lastnight and its 100% hex at the top of the injector which requires a 21mm deep socket to pull out.
Sorry, the Mk6 was never released with a 2.2 engine, if as our Altransit suggests, it has a Mk7 engine in it, the injectors just pull out after the clamps are removed.
Can you take a photo of the engine for us..?? Do your injectors have any wiring to them..??
Does your engine look like this one..??
Or does it look like this one..??
