Red one
Re: Loots mk7 keeper
Postby ned » Fri May 02, 2025 7:52 am
I’m not planning on doing it, one sld is enough for me and even that’s a bloody pain sometimes :lol:
If I do do ( :lol: :lol: do do) the drivers side fuel filler I’d probably run the fuel pipe through the van and down through the floor, it’ll probably never happen
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby loot » Sat May 03, 2025 5:22 pm
ned wrote:I’m not planning on doing it, one sld is enough for me and even that’s a bloody pain sometimes :lol:
Well you know the saying,if you really want it then it can be done :P
07 350 170ps
Ids map here
loot
Postby loot » Sat May 03, 2025 5:32 pm
What a fook up.
So despite me being tight,I saw a new side door step trim for the van and there was a 20% discount. I thought ok i paid 40 for 1 second hand 10 years ago and it finishes the rear compartment nicely. They look the same from left to right but buy the 1 and see.
The right 1 is hens teeth and more likely found in europe.
YC15-V13249-AEYYGL UK passenger side (the 1 i bought from ebay uk )
YC15-V13246-AGH is for the uk right drivers side. Ford can't get them and only 3 used ones exist on the Web.
I asked the ebay seller but they're plugged in.sorry no we can't get it.
Anyway the 1 that arrived has the part numbers.
YC15-V13248-AEYYGL but the 8 is clearly printed over the 6 :lol:
And I placed it on both sides of the van and it is good and fits. But the pisser is that I'm no longer offered the 20% discount on
ebay :roll:
I've put it in watched and hopefully the coupon will come up again :mrgreen:
07 350 170ps
Ids map here
loot
Postby Airthies » Mon May 05, 2025 7:26 am
loot wrote:
ned wrote:Nice how low is the roof chop gonna be 6” are you putting a low roof on or high top/pop top, you know with the donor van you could make a funny van where you cut the middle out.
Quick question are the outer cills spot welded to the inner cill
I'm stitching the low roof on from the tourneo it'll be factory.
I might cut the middle out and fit a pop top. But that's a later project. I've still got loads to do, insulation, tourneo interior,stretch carpet etc, there's a leak from the gearbox to engine seal. I'm interested in fitting a mustang automatic gearbox if possible. Remap possibly. I did have the pcm in it from snowflake but I had to install the original map. I could put a 3.2 pot in it if I wanted. Also I'm interested in upgrading the speedo and adding sync 3. If possible.
It's a long term project and I can get it on the road first.
Panels are all spot welded, they sandwich together. Did you post a picture of your panels anywhere? There's genuine fit ones or repair panels which are different. They're doesn't appear to be factory inner sills available for the non sliding door side :x
Looking good squire, that's some love going into that.
Re the Mustang auto I can't find any that match the puma bell housing, the Mustang box is for the petrols.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Mon May 05, 2025 7:06 pm
Hi Iain, that's a pisser isn't it :cry: it looked close to the eye didn't it. I'm sure something will fit.
07 350 170ps
Ids map here
loot
Postby Airthies » Mon May 05, 2025 9:10 pm
loot wrote:
Airthies wrote:
loot wrote:[quote="ned"]Nice how low is the roof chop gonna be 6” are you putting a low roof on or high top/pop top, you know with the donor van you could make a funny van where you cut the middle out.
Hi Iain, that's a pisser isn't it :cry: it looked close to the eye didn't it. I'm sure something will fit.[/quote]Ranger box and adapt the output shaft splined flange to either rubber donut or UJ
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Wed May 07, 2025 12:34 pm
Right so I like the transit floor as it is easy to clean. But I like the sound proofing and insulating properties of the tourneo carpet, but I'm not a fan of the grey colour.
I saw that you can buy carpet dye for vehicles . No idea if it is any good though.
Also is the tourneo carpet a ho to clean.
So armed with some washing gel and my 2 jet washing machines I thought I'd have a look.
What do you think chaps?
Probably do a bit more but I think it looks good. Might try the other bits of carpet. I'm going to do the interior in anthracite or black stretch carpet so I think I'll need to dye the floor
07 350 170ps
Ids map here
loot
Postby ned » Wed May 07, 2025 5:49 pm
It’s green, is the carpet dye like the headlining and fabric dye stuff? If it is I’d recommend spraying it on, my daughter used some with a paint roller on the Alfa roof lining and it’s fooking patchy as fook.
ned
Postby loot » Wed May 07, 2025 11:26 pm
ned wrote:It’s green, is the carpet dye like the headlining and fabric dye stuff? If it is I’d recommend spraying it on, my daughter used some with a paint roller on the Alfa roof lining and it’s fooking patchy as fook.
It's like a blue green, I've been looking at carpet dye black but in the photos it looks a bit gash, so might have to stay with this colour, I'll see what the other bits come up like,if not very good then I might cancel it.
07 350 170ps
Ids map here
loot
Postby loot » Fri May 09, 2025 11:07 pm
Did the rest of the carpet,looks lovely. And today I started spraying some bits with primer
07 350 170ps
Ids map here
loot
Postby loot » Thu May 15, 2025 10:05 am
What a week of humbug.
So i have some plastic bits to paint and got it in my head that I need etch primer. Well no actually you need plastic primer stupid.
Plus I bought 1k and 2k basecoat and 1k lacquer.
Why? Well Google of course. Which tells you different things :roll:
Anyway I splashed all of that onto some bits which looked lovely until I did the lacquer which as soon as I put the spray gun down all turned to mush.
Spent the day sulking,but I then went to a local panels and paints place. I bought some 2k filler primer and I have some 2k lacquer from many years ago that the paint man says it's good as long as it doesn't glue up.
So last night I spent 2 hours with the wire wheel on the drill sanding all of the paint off. Try again shall i!
Where was mr Ned when you need him to tell you about paint wotnot.
Oh i instinctively pressed reverse on the wire when when it bunched my t shirt which was actually worse as the bristles dug in :oops:
07 350 170ps
Ids map here
loot
Postby loot » Thu May 15, 2025 10:16 am
This was the reaction
07 350 170ps
Ids map here
loot
Postby Altransit » Thu May 15, 2025 1:25 pm
Looks a bit like when you spray cellulose on top of synthetic :?
Postby ned » Thu May 15, 2025 5:03 pm
I’m no car paint expert but what mix did you do with the lacquer? Will it not flat with 1500 wet n dry
ned
Postby loot » Thu May 15, 2025 10:35 pm
ned wrote:I’m no car paint expert but what mix did you do with the lacquer? Will it not flat with 1500 wet n dry
I was told that using 1k clear lacquer on 2k base equals paint stripper
I tried flatting them first but sticky paint even though dry and sandpaper is evil too work with.
I used the wire wheel and removed every trace of red paint. And tonight I primered the panels and the van in filler primer
07 350 170ps
Ids map here
loot
