T350camper wrote:Hi Dan,
Is that the same for Mk6? Forscan says mine is a 2005 model year (although registered in 2006) 2.4 TDCI 135bhp RWD
Van runs very well, and since blanking the EGR there is no visible smoke from the exhaust. Only slightly annoying issue is a bit of a lumpy idle, although it never feels like it might stall, just has a tiny miss which stops as soon as any throttle applied (even by 50rpm). Mileage is only 34,000
I was thinking of trying to do learns when I service the van in a month or so but don't want to give myself a problem. There are no DTC's in any system and the old adage 'if it ain't broke, don't fix it' lurks in the back of my mind alongside the other cobwebbs
DanMK7uk wrote:Yes, certainly worth doing.its a service procedure which many neglect.
To confirm is yours euro 4 ? Else its non applicable.
Yes it should help smooth things out, however if your scv is not healthy it may still require replacing anyhow. Some even clean them out, but genuine Denso valves can be had for 60 bob. Watch out for fakes !
Its a good starting point running the learns however.
Clutch in can make them hunt. Fairly normal.
Other than that it would suggest fuel pressure may be a little out due to scv often.
Go on to the service functions on forscan, it will run you through the process, reset prv open duration, fuel pump learn followed by injector pilot learn. All simple to follow .
Tbh as long as the van starts and drives id be surprised if it caused any issues with it failing, they sometimes fail due to fuel temps, id recommend doing on a cold engine and bring it up as your doing it.
DanMK7uk wrote:Yes mate, live data get up fuel pressure actual and desired.
You want 230 bar at idle + / - 10%.
If its oscillating erratically with hunting then thats the scv most usually.
vansit1 wrote:what does the Prv open thing show/tell to the car?
Users browsing this forum: gt_addict
