About 2k boosts comes in lags then comes back in.
No codes
New turbo about 1k on it, wasn’t apparent when fitting new issue
Thinking should i check veins not sticking ?
Drives ok otherwise
DanMK7uk wrote:About 2k boosts comes in lags then comes back in.
No codes
Drives ok otherwise
knobby1 wrote:DanMK7uk wrote:About 2k boosts comes in lags then comes back in.
No codes
Drives ok otherwise
Niether of your vans listed in your signature should have "vanes" on the turbo, (it won't have "veins" unless pumping blood)...they should both be wastegate type.
Check for sticking actuator arm or its pivot point.
metalworker0 wrote:You need a scanner on it.
in the mean time there are few checks you can do on it
not sure which is which now as you have two vans listed
EGR
check with forscan to see if its opening and sticking etc
did you have waist gate trouble ? have you fixed this properly.
not sure what ive been through with you
leaky boost pipes?
Not sure if was you ..spraying cleaner down the first rubber air cleaner hose is not close enough .. needs to be undone at the turbo to clean it.
says engineer in your profile, so i don't need to add much more. if a mechanical one .
what sort of engineer?
No codes
Drives ok otherwise
Haha![]()
DanMK7uk wrote:No boost leaks, vac hose all ok
DanMK7uk wrote:Rightyo cheers for clarifying
How involved to fit a boost gauge to one of these machines?
Where would I T from ?
DanMK7uk wrote:Very tidy.
I like it.
Clean motor that too.
