NS front outer cv boot split
Postby DanMK7uk » Mon May 12, 2025 5:26 pm
Noticed when putting air in tyres,
Splashed fair bit up arch and lower arm
How bad to remove to do a boot and repack the joint ?
DanMK7uk
Re: NS front outer cv boot split
Postby gt_addict » Mon May 12, 2025 6:06 pm
Its a job I’ve never undertaken because I haven't got a boot stretcher to get it over the knuckle. Last one I did on my Connect I had to deconstruct the knuckle first. Bloody messy job. Also got the hub nut to deal with at 450nm and the standard being careful with driveshaft seals.
gt_addict
Postby DanMK7uk » Mon May 12, 2025 6:14 pm
I might just change the shaft tbh mate
Whats the probability of the shaft coming out the hub lol
DanMK7uk
Postby gt_addict » Mon May 12, 2025 6:14 pm
Very likely with a decent size persuader :lol:
gt_addict
Postby metalworker0 » Mon May 12, 2025 6:24 pm
Order a borg and back one ..thicker and durable
Easier to do with the drive shaft out
May as well do inner at the same time
they are a serviceable item (even though no maintenance manual ever tells you that) ...and if you wanted longevity you'd probably take them apart every 60,000 miles, clean, regrease / reboot
... But ..i'm sure this is the same with transit 6/7 as it is with the connect
in which case a whole brand new drive shaft made by borg and beck can be found on ebay for £70 ish
worth thinking about
Postby metalworker0 » Mon May 12, 2025 6:49 pm
£ 82
https://www.ebay.co.uk/itm/316100130554?
and for the long one with bearing in the middle
£105
https://www.ebay.co.uk/itm/335890810202?
both borg and beck and from trusted ebay seller ive dealt with before .
Postby DanMK7uk » Mon May 12, 2025 7:42 pm
Appreciate that Mark,
Gosh thats better than BMW asked for one for my M3. £500 !
DanMK7uk
Postby DanMK7uk » Mon May 12, 2025 7:44 pm
metalworker0 wrote:£ 82
£105
Hopefully the oil seals are readily available for the inner end !
Il have to have a look on cat car
DanMK7uk
Postby metalworker0 » Mon May 12, 2025 8:25 pm
think you'll need a very large torque wrench, 3/4 drive , if i have info right
some one verify
420NM
Postby knobby1 » Mon May 12, 2025 9:00 pm
metalworker0 wrote:think you'll need a very large torque wrench, 3/4 drive , if i have info right
some one verify
420NM
They're actually 500nm or 370lb-ft.
Postby metalworker0 » Mon May 12, 2025 9:08 pm
that's the rear . that they call the "half shaft" is it not
Postby knobby1 » Tue May 13, 2025 12:58 am
metalworker0 wrote:that's the rear . that they call the "half shaft" is it not
Pretty sure it says "front suspension" on the table.
The RWD "front spindle" nuts are only 440nm.
The RWD 65mm hub nuts are 425nm.
Postby DanMK7uk » Tue May 13, 2025 1:05 am
Mines FWD guys (should of said)
DanMK7uk
Postby DanMK7uk » Tue May 13, 2025 1:08 am
Either way i do not have a TR to that value, it will be done up with a breaker bar and il have my weetabix, greek yogurt honey and blueberries first .
That bugger wont come loose lol
DanMK7uk
Postby knobby1 » Tue May 13, 2025 1:25 am
DanMK7uk wrote:Either way i do not have a TR to that value, it will be done up with a breaker bar and il have my weetabix, greek yogurt honey and blueberries first .
A 1/2" breaker bar won't be good enough, they snap at anything close to the correct torque....you'll need at least a 3/4" knuckle bar and a goodly amount of pipe on the end.
Just for reference...500nm is 500kg at a distance of 1 meter from the axle. So even with a 2m long knuckle bar, you'll need to weigh or be able to lift 250kg.! :lol:
There are "torque multipliers" made for this purpose.
https://www.ebay.com.au/itm/33514929716 ... earch=true
