tranmx2 wrote:
Basically for an engine to work it needs an unrestricted supply of air and fuel and an unrestricted outlet/exhaust.
knobby1 wrote:Nick_B wrote:Im going to take out the injectors again and see if there's any carbon build up. I also need to inspect the injector nozzles to see if there are any blockages.
I've seen a few videos on youtube where they've taken the tip of the injector off to clean it and test the spray pattern.
How are you going to test them..??
You need specialist equipment to do this....these nozzles are electronic and run at up to 1600bar or 26,200psi.
Nick_B wrote:Turbo still not working
I’ve made a short video showing the values on forscan I have no idea what the values should be or what they should be doing.
I’m revving to about 2500 revs and the boost value only changes when I take my foot off the accelerator. They drop then go back to 80
https://youtube.com/shorts/9DmSc56Bt3E? ... hZZkMQIAif
gt_addict wrote:It was the MAF sensor?
Thats a blue moon event. According to the forum they rarely fail.
Only just seen your vid and FRP seems fine. MAP only went upto 20psi or so. My EU5 125ps peaks at about 34psi under full throttle and settles around 30psi sustained.
Any noticeable signs of damage on the MAF? What brand was the old one and what did you replace it with?
vansit1 wrote:vansit1 wrote:post live Maf, Map and Egr readings too and this probably has some turbo data visible too?
have you done that?
+obvious Dpf values on euro5
