Mk7 2.4 rwd duel mass fly wheel query
Postby trannyfreak » Mon May 26, 2025 11:19 am
Hi all, my spigot bearing has fell to bits,so wanting to replace it, I've took off the clutch, but wanting to remove the flywheel for better access, I've tried everyway to turn it so I get to the bolts but it won't move, so how do I get to the bolts? Many thanks
trannyfreak
Re: Mk7 2.4 rwd duel mass fly wheel query
Postby andz327 » Mon May 26, 2025 4:30 pm
Flywheel is knackered
andz327
Postby trannyfreak » Mon May 26, 2025 5:00 pm
I thought so ok many thanks
trannyfreak
Postby Altransit » Mon May 26, 2025 5:22 pm
You can't rotate the flywheel to expose the bolt heads :?: :?
Postby trannyfreak » Mon May 26, 2025 5:28 pm
How do you get onto the bolts to remove the flywheel then? Many thanks
trannyfreak
Postby tranmx2 » Mon May 26, 2025 5:47 pm
The bolts are in the crank shaft.
The fly wheel needs to move to access the bolts.
Make a piece to hold the crank shaft - the pully - it has a rubber cush drive which could break. Remove the pully make a piece that can be held by the pully bolts.
The flywheel can be moved with the crank held.
Use a strap around it or lever across the front of it.
Either the crank is moved or the flywheel is moved/rotated to get at the bolts.
If the injectors are still in - better to hold the crank and move the flywheel.
There are ways to remove the spigot bearing. It is an interferance fit.
I used a small rotating grindstone and small chisel to remove the one in the 2012 which is not the conventional way to do it.
The spigot bearing is in the crankshaft.
The image of the spigot looks like one roller has been displaced - the grease looks good in there there does not appear to be any damage.
Use a bent wire/spike to move the roller back to its positon - use a finge inside to rotate the rollers and feel for grittiness.
If they rotate smoothly likely the spigot is okay.
Look at the end of the shaft that goes into the spigot at the bell housing see if that is damaged.
2012 MK 7 E 5 100-350 3.5 XLWB RWD Duratorq 2.2L CR TC 14 DSL 100/125 PS
Was DRRB 74 KW 100 HP 100 cv. Now CYR5 125 HP. PCM could still be for 100 HP. Siemens Continental fuel system.
OBD2 ELM 327 FTDI with switch from Tunnel rats. Forscan 2.3.46
tranmx2
Postby trannyfreak » Mon May 26, 2025 7:35 pm
Brilliant bit of advice, thankyiu, so tge mass flywheel is not knackered I was thinking it had siezed, I will play with the roller tomorrow and put ut back into its location many thanks again
trannyfreak
Postby knobby1 » Mon May 26, 2025 7:53 pm
trannyfreak wrote:Brilliant bit of advice, thankyiu, so tge mass flywheel is not knackered I was thinking it had siezed, I will play with the roller tomorrow and put ut back into its location many thanks again
Your flywheel is indeed knackerd, should only move a few degrees...just put a lever in one of the holes and push/lever outer part of the flywheel around to allow access to the bolts.
You should be able to move it a little by hand.
Postby trannyfreak » Mon May 26, 2025 8:00 pm
No mate it's completely solid it just turns the the engine, when I removed the gearbox it there was a lot of dust and smelt like burnt clutch, but the van has been sat four years, and the bloke I brought it of drove it to me about 70 miles away, so how woukd I remove this flywheel, I've ordered a new one with all new clutch too many thanks
trannyfreak
Postby knobby1 » Tue May 27, 2025 12:35 am
trannyfreak wrote:No mate it's completely solid it just turns the the engine, when I removed the gearbox it there was a lot of dust and smelt like burnt clutch, but the van has been sat four years, and the bloke I brought it of drove it to me about 70 miles away, so how woukd I remove this flywheel, I've ordered a new one with all new clutch too many thanks
Should still move with a bit of force.
Holes should line up and look like this one when it's new.
Postby trannyfreak » Tue May 27, 2025 7:47 am
Ok mate ill give it another go today, and let yiu know how it goes many thanks
trannyfreak
Postby T350camper » Tue May 27, 2025 3:48 pm
Can you get the end of a strong flat blade screwdriver in one of the holes and lever against something on the flywheel (the head of a bolt or a dowel etc)? That way your not trying to rotate the engine, just bring the bolts into line with the holes.
2006 Mk6 T330 135bhp 2.4TDCI
T350camper
Postby trannyfreak » Tue May 27, 2025 5:39 pm
Right I tried everything it just seems like it is siezed, tried locking front of engine via the crank, put a bolt in one of the gearbox mounting holes got big pry bar even stood on the bar for more leverage, just won't budge
trannyfreak
Postby tranmx2 » Tue May 27, 2025 9:39 pm
Moved the 2012 less than yours needs to be moved.
It was moved in the same direction as the eng' DOR.
Not sure if it was T 60 as a T 55 was also used.
tranmx2
Postby T350camper » Wed May 28, 2025 10:22 am
As some of the other advice. Try to insert a strong screwdriver or prybar into one of the holes and lever against the bolt head so that you are forcing the 2 halves to turn in opposite directions. Just enough to gain access.
If you really can't budge it at all, even this way, then considering that you're going to bin the whole thing and fit new parts, then perhaps a grinding disk could be used to cut away some of the material obscuring the bolts? Just be careful.
T350camper
