Stevelien wrote:Is there anyone who has the golden solution for the 2.0 TDCI limp mode during load changes. I read that this often occurs with 2.0TDCI but never read a solution for this. All suspicious items have been replaced including pump and injectors and sensors. My 2.0TDCI also suffers from this, especially when shifting down and then back on the gas, overtaking and U-turns, for example. No fault codes, low power and it is away after a restart. To the touch it feels like the engine is choking on something... it never happens during gentle acceleration. Engine is almost brand new, chain, turbo, hoses, everything. Pump pressure is excellent. I read on a Belgian forum that this was due to tuning on a Mondeo mk3 2.0TDCI, but I don't suspect that my Transit has been tuned except for the factory boost function. I also read that a few had changed the electronic accelerator pedal with no result.
DanMK7uk wrote:Incorrectly timed fuel pump is what it sounds like.
Wint disagree with thatDanMK7uk wrote:I should read better !!
He had only mentioned it was TDCI x 4 times![]()
Dont get old!
knobby1 wrote:Stevelien wrote:Is there anyone who has the golden solution for the 2.0 TDCI limp mode during load changes. I read that this often occurs with 2.0TDCI but never read a solution for this. All suspicious items have been replaced including pump and injectors and sensors. My 2.0TDCI also suffers from this, especially when shifting down and then back on the gas, overtaking and U-turns, for example. No fault codes, low power and it is away after a restart. To the touch it feels like the engine is choking on something... it never happens during gentle acceleration. Engine is almost brand new, chain, turbo, hoses, everything. Pump pressure is excellent. I read on a Belgian forum that this was due to tuning on a Mondeo mk3 2.0TDCI, but I don't suspect that my Transit has been tuned except for the factory boost function. I also read that a few had changed the electronic accelerator pedal with no result.
You mention you van has gone into "limp mode"...but then you say you have no fault codes....if it has actually gone into limp mode, there "will" be fault codes stored. What code reader was used..?? Mk6 is not OBD-II compliant so most of the newer readers won't work.
Stevelien wrote:knobby1 wrote:Stevelien wrote:Is there anyone who has the golden solution for the 2.0 TDCI limp mode during load changes. I read that this often occurs with 2.0TDCI but never read a solution for this. All suspicious items have been replaced including pump and injectors and sensors. My 2.0TDCI also suffers from this, especially when shifting down and then back on the gas, overtaking and U-turns, for example. No fault codes, low power and it is away after a restart. To the touch it feels like the engine is choking on something... it never happens during gentle acceleration. Engine is almost brand new, chain, turbo, hoses, everything. Pump pressure is excellent. I read on a Belgian forum that this was due to tuning on a Mondeo mk3 2.0TDCI, but I don't suspect that my Transit has been tuned except for the factory boost function. I also read that a few had changed the electronic accelerator pedal with no result.
Yes indeed, forscan gives code P0251, I have seen that coming by before after limp mode (but I get another OBD not working indeed on Transit).
But I have already checked all the things in this error code, I have a pump test report with values that are more than good at all rpm's. It also fell into this limp mode with my previous pump, so I replaced this pump preventively with injectors, filter, sensors and all lines checked and flushed. It remains a mystery. The DPF particulate filter has been switched off once and written away from the ECU, perhaps this has something to do with it, it has more power, a higher flow now that the ECU control cannot handle and adjusts, I'm just mentioning something. But it happens at lower speeds around 2500 rpm as I indicated, when I shift from first to second gear at the bottom of the rev range and give a lot of gas. Or from 5 to 4 when climbing. I see multiple posts with this problem with the 2.0tdci (Jaguars X type/Mondeos). That technical service bulletin 46/2005 describes it well but doesn't really provide a solution other than the standard things that I've already replaced or checked.
ned wrote:2003 2.0L tdci is euro 3 not euro 4.
Anyway there a bloody nightmare you’ll be chasing the fault for years, the only thing I can say to check is the wiring loom from the injectors ect down to the fuel pump, it runs behind the manifold iirc and can rub through the wiring causing an short in the wire.
wojciech wrote:Don't believe in assurances that the injectors are good and the pump is good. Check them yourself.
For the injectors, do a fuel return test (in Polish we call it a flow test). This test tells you almost everything about the injector match, and especially whether the injector valves are efficient (new). Basically, only the original Delphi valves work properly. There are a lot of replacements on the market, usually they are junk.
If this test is positive for the injectors, connect a good tester and check the rail pressure while driving, especially during hard acceleration. Is the rail pressure consistent with the one set by the PCM.
There can be a hundred or more reasons for the P0251 error to appear. This is a favorite Mk6 tdci error.
Check the suction strainer in the fuel tank and whether the tank aeration is working properly (whether negative pressure is created there while driving).
