Cam chain change
Cam chain change
Postby longhair » Tue May 27, 2025 10:45 am
My 2014 custom has done 155 thousand miles, so I'm thinking about fitting a new chain and tensioner. Can anyone recommend a decent make to get, or am I better playing it safe and paying more for genuine Ford kit.
longhair
Re: Cam chain change
Postby metalworker0 » Tue May 27, 2025 1:16 pm
Look for German chains -- hard to see in the ebay pictures, they usually have IWIS stamped on the links, FEBI Bilstein use IWIS chains
Makers - Look for Renold, SKF , IWIS, DID, are a just a few i know as being quality.
SKF are Swedish, DID are Japanese, Renold are British , IWIS are German.
Be very careful, as some English sounding names or makes have Chinese parts in them - avoid!
Do your research
Think some Ford OE chains are IWIS
Postby andz327 » Wed May 28, 2025 11:57 am
I always use ULTRAPARTS Kits, they use genuine Ford/PSA parts in these kits unless they can supply a specific part that is better than genuine ,
I've personally used ultraparts for over 25yrs (head sets, engine rebuild kits , timing chain kits etc ) and never had a problem.
On ebay "aapoldham" does good prices for Ultraparts
https://ebay.us/m/7HcuWS
https://ebay.us/m/ZyUsLx
andz327
Postby longhair » Wed May 28, 2025 5:25 pm
Cheers, I'll have a look.
longhair
Postby Radiofence » Thu May 29, 2025 10:17 pm
I got my kit from Tpuk. I they said it was oem. The tensioner was but the rest I'm not sure. The cam and exhaust cog tbjbfs didn't have the same nice tooth shape that the originals had, I wish I had just left the originals.
That aside, it's been fine since.
Transit custom 2.2
Radiofence
Postby longhair » Fri May 30, 2025 8:49 am
I think I'm just going to be changing the chain and tensioner if I can get away with it.
longhair
Postby metalworker0 » Fri May 30, 2025 12:36 pm
btw .you'll need the tin cover, if you do this job, as it will be bent distorted and destroyed taking it off
Postby longhair » Fri May 30, 2025 4:41 pm
Oh I see, I thought it was only the wet belt engine that did that.
longhair
Postby knobby1 » Fri May 30, 2025 9:40 pm
longhair wrote:Oh I see, I thought it was only the wet belt engine that did that.
Very rare to get the timing cover off without bending it on any of the Transits. Snapping bolts/studs is a common issue too.
Postby DanMK7uk » Sat May 31, 2025 12:13 am
Same principle the chain is wet in oil.
DanMK7uk
Postby knobby1 » Sat May 31, 2025 9:23 pm
longhair wrote:I think I'm just going to be changing the chain and tensioner if I can get away with it.
Guides will be worn too...silly not to at least do them too whilst you're in there.
Postby longhair » Sat May 31, 2025 11:35 pm
Yeah I am changing those too.
longhair
Postby Radiofence » Sun Jun 01, 2025 9:37 pm
Like knobby said - I was going to be my normal stingy self, but eventually got the whole kit. The guides were worn a lot. Deep grooves in them.
Transit custom 2.2
Radiofence
