DanMK7uk wrote:Almost certainly injector seals.
Be sure to ream / clean the seats when refitting new copper washers.
Be sure to replace the stretch bolts too.
Not sure on your euro5 but euro 4 is 6nm plus 180 turn..
Hopefully someone can confirm for you..
DanMK7uk wrote:Yh absolutely fine, keep eye on oil levels.
I normally suggest changing the oil after doing seals though not absolutely necessary.
andz327 wrote:Fookin ell mucker your going for with all that gear you've ordered
On another note with your engine being a euro 5 it may well need a replacement cam cover as the crank case breather is part of this and can cause the problem your having if faulty, only 10mls a day isn't good for these engines your said its driving you nuts ..... with what????
metalworker0 wrote:think euro 5 is indicated by the orange rubbers on the inside ..they seem to be sort of orange on that one
so if you have euro 5 its the right one.
and the vendor is saying in description
FORD TRANSIT MK7 2.2 TDCI (2011-2014)
FORD TRANSIT MK8 2.2 TDCI (2014 ONWARDS)
FORD TRANSIT CUSTOM 2.2 TDCI (2012 ONWARDS)
BTW ..someone here bought one off ebay here were the holes weren't drilled through ..so always a risk
Users browsing this forum: Bing [Bot], g-man
