Oil around injectors.
Postby PLEDGEY » Mon Jun 02, 2025 4:10 pm
2013 plate FWD, SWB, 2.2 MK 7 .Took the air filter housing and rubber cover off and the first 2 injectors, going left to right, have oil all around them, it's on the under side of the rubber cover as well. Also, when the van is running on tick over, and you take the oil filler cap off, a white vapour/mist comes out, not all the time, just after you take the cap off. It seems to be blowing out the cap, like it's under pressure. Any one got an idea what this could be, cheers!.
PLEDGEY
Re: Oil around injectors.
Postby DanMK7uk » Mon Jun 02, 2025 6:20 pm
Almost certainly injector seals.
Be sure to ream / clean the seats when refitting new copper washers.
Be sure to replace the stretch bolts too.
Not sure on your euro5 but euro 4 is 6nm plus 180 turn..
Hopefully someone can confirm for you..
DanMK7uk
Postby PLEDGEY » Mon Jun 02, 2025 6:45 pm
DanMK7uk wrote:Almost certainly injector seals.
I got it booked in for an MOT on the 16th of this month. I'll just get them to do it. This van is driving me nuts!. Is it still O.K. to drive?. I'm doing literally 10 mile a day at the moment. Cheers.
PLEDGEY
Postby DanMK7uk » Mon Jun 02, 2025 7:11 pm
Yh absolutely fine, keep eye on oil levels.
I normally suggest changing the oil after doing seals though not absolutely necessary.
DanMK7uk
Postby PLEDGEY » Mon Jun 02, 2025 7:35 pm
DanMK7uk wrote:Yh absolutely fine, keep eye on oil levels.
Just watched a few vids of people changing the seals and going to give it a go my self. Ordered an injector seat ream kit, a washer puller tool, injector seat brush cleaning kit, injector seals, bolts, washers and an inspection camera. Just gonna' take it easy, from what I can gather it's a 17mm flat cutter, use grease to collect swarf, don't get injectors mixed up. Got 2 chances....fingers crossed. :D
PLEDGEY
Postby DanMK7uk » Mon Jun 02, 2025 7:57 pm
Pretty much mate.
Take your time your be fine.
Injectors can be tight to get out but give them a twist and should pop out
A bit of cardboard with some holes in to bank them in order is a good idea
1234
DanMK7uk
Postby andz327 » Mon Jun 02, 2025 9:55 pm
Fookin ell mucker your going for with all that gear you've ordered
On another note with your engine being a euro 5 it may well need a replacement cam cover as the crank case breather is part of this and can cause the problem your having if faulty, only 10mls a day isn't good for these engines your said its driving you nuts ..... with what????
andz327
Postby vansit1 » Tue Jun 03, 2025 2:17 pm
bolts and return lines have seals too
vansit1
Postby PLEDGEY » Tue Jun 03, 2025 6:01 pm
andz327 wrote:Fookin ell mucker your going for with all that gear you've ordered
All of the parts and tools came to......£75, all off Ebay, that's why I thought I'd have a go myself. For the last 3 years I been driving 100 mile a day, but the last 6 months the jobs been on my doorstep, hence the 10 miles. I do take it for a blast down to Exeter when I see the D.P.F. differential pressure start to go up.. I've had a new engine at 70k, no end of D.P.F. issues that no one was able to fix. I ended up getting a diagnostic tool with a live data feed and, after watching videos on Youtube, took the whole D.P.F. off and cleaned it, replaced the vaporiser that was blocked and replaced a dead d.p.f.differential pressure sensor. Had it back in the garage for, I think, the issue I got now twice. Going to order a crank case as if it is a blocked breather and they didn't replace it last time it'll happen again.
PLEDGEY
Postby PLEDGEY » Tue Jun 03, 2025 6:21 pm
Is this the cover I need for a mk7 FWD T280 SWB 2.2 ON A 2013 Plate ?. Looks the same but then I've bought 'wrong stuff' before, cheers.https://www.ebay.co.uk/itm/173960052657 ... UIa35OzmZQ
PLEDGEY
Postby metalworker0 » Tue Jun 03, 2025 6:54 pm
think euro 5 is indicated by the orange rubbers on the inside ..they seem to be sort of orange on that one
so if you have euro 5 its the right one.
and the vendor is saying in description
FORD TRANSIT MK7 2.2 TDCI (2011-2014)
FORD TRANSIT MK8 2.2 TDCI (2014 ONWARDS)
FORD TRANSIT CUSTOM 2.2 TDCI (2012 ONWARDS)
BTW ..someone here bought one off ebay here were the holes weren't drilled through ..so always a risk
Postby PLEDGEY » Wed Jun 04, 2025 5:22 pm
metalworker0 wrote:think euro 5 is indicated by the orange rubbers on the inside ..they seem to be sort of orange on that one
Thanks for that. Might as well get it right first time :-)
PLEDGEY
