Torque Setting MK7 2.2 Injector bolt?
Postby Surfunitone » Wed Jun 12, 2013 10:44 am
hey gang, ive looked for this on the forum and cant seem to locate it, can someone please help me?
thanks
2.2 Duratorq-TDCi (110PS)
Surfunitone
Re: Torque Setting MK7 2.2 Injector bolt?
Postby fedup2 » Wed Jun 12, 2013 2:43 pm
6nm and 180 deg
Launch x431 owner ;)
fedup2
Postby fedup2 » Wed Jun 12, 2013 2:45 pm
if you have the bottle :)
They snap very easy.I greased under the bolt head and did them till they felt tight enough and ignored the torq wrench.
make sure you use new bolts.stock item.
fedup2
Postby belly » Wed Jun 12, 2013 6:26 pm
fedup2 wrote:6nm and 180 deg
fedup2 wrote:if you have the bottle :)
make sure you use new <span class="skimwords-unlinked">bolts.stock</span> item.
Just done my 3.2, it's the 180deg that's sketchy :shock: The fifth injector setup is 5nm and no 180 deg :D
belly
Kaiser Chief
Postby Surfunitone » Wed Jun 12, 2013 9:13 pm
I'll got for 6 and bit ;) all New bits so I should be fine!!
Surfunitone
Postby Surfunitone » Thu Jun 27, 2013 11:04 am
what that in pounds feet? ive got an older torque wrench
Surfunitone
Postby loot » Thu Jun 27, 2013 1:32 pm
I'm getting 4.425372895662
:o
07 350 170ps
Ids map here
loot
Postby Surfunitone » Tue Jul 02, 2013 9:46 am
I converted it to that And my wrench doesn't go that lol.... I thought I had it worng...
Surfunitone
Postby PLEDGEY » Wed Jun 04, 2025 5:21 pm
The 180 degrees, is that, like , half a turn to achieve the 6 Nm?.
PLEDGEY
Postby DanMK7uk » Wed Jun 04, 2025 5:47 pm
+180
After 6nm
Hopefully after 12 years op got it done
DanMK7uk
Postby knobby1 » Wed Jun 04, 2025 8:39 pm
PLEDGEY wrote:The 180 degrees, is that, like , half a turn to achieve the 6 Nm?.
No...it's 6nm, (4.425lb-ft or 53.1lb-in), and then another 180 degrees or half turn.
1 Newton is eaqual to 0.981kg/f....or 1kg is equal to 9.81newtons.
For the conversion...1nm is 0.7376 lb-ft or basically multiplied by 12 to get 8.8512 lb-in.
Sorry...I'm a bit of a numbers man. :roll:
Postby DanMK7uk » Wed Jun 04, 2025 8:56 pm
Im starting to think our knobby is AI lol :lol:
DanMK7uk
Postby PLEDGEY » Wed Jun 04, 2025 9:13 pm
Ah sweet, now it makes sense. Thanks!
PLEDGEY
Postby andz327 » Thu Jun 05, 2025 9:10 am
Are you sure it makes sense
andz327
Postby vansit1 » Thu Jun 05, 2025 12:27 pm
how many kw is that 2.2?
vansit1
