Antuk wrote:Got a red flashing light on my van and wont start its a mk7 2.4 rwd its just had 2 new batteries and when I plug in obd it wont read any ideas ive checked all the fuse
gt_addict wrote:Not sure about coding but you’ll need the mileage changing afaik. Unless that info is stored in the BCM/PCM/ECU I’m not sure.
Antuk wrote:instrument cluster is beyond repair that's what's at fault been told need a new one anyone know if it needs coding to the van ?
Altransit wrote:Antuk wrote:instrument cluster is beyond repair that's what's at fault been told need a new one anyone know if it needs coding to the van ?
No it doesn't need coding, but, as above, you're stuck with whatever mileage is stored in the clocks that you buy.
knobby1 wrote:I believe somebody like our "Vantuner" may be able to "manipulate" the mileage...but I suspect he'd need the van with clocks fitted to do that.
Users browsing this forum: Y98jpa2
