Which fuses am I missing?
Postby bobbybobson » Tue Jun 10, 2025 1:28 pm
Can someone with a 2018 tell me which fuses/relays I'm missing here? Currently when I turn the key I get lights on the dash but no starter motor.
bobbybobson
Re: Which fuses am I missing?
Postby metalworker0 » Tue Jun 10, 2025 2:11 pm
Should be written on the inside of the lid what goes where
or 2018 owners manual here ..scroll down to fuses ..there is a picture of each fuse box with numbered fuses and relays, with a chart explaining what the fuses or relays do
https://www.fordservicecontent.com/Ford ... ldtype=web
EURO STAGE 6 OR EURO STAGE 6.2 ..THAT I DON'T KNOW! perhaps it says on the sticker on the inside of the door pillar
Postby andz327 » Fri Jun 13, 2025 12:44 am
Whzt do you think has happened that they're missing...... fuse and relay theft?????
andz327
Postby Altransit » Fri Jun 13, 2025 11:34 am
Is this the van that had wet belt failure :?:
Postby DanMK7uk » Mon Jun 16, 2025 9:11 pm
https://www.startmycar.com/gb/ford/tran ... orfusebox0
Hopefully this is constructive for you to work out
DanMK7uk
Return to Transit Custom
