Vaccum gasket thickness
Postby Salisburytree » Mon Jun 09, 2025 9:04 pm
Would anyone happen to know of Ford issuing a set thickness for the gasket between between vaccum and water pumps.
Ordered new gaskets today and the vaccum gasket seems to be twice as thick as what I took off. Also fitted a new water pump that came with two gaskets that are the same thickness as the originals (might not be ford original, but what I took off the engine)
Mk6 2.4 rwd 2006
Salisburytree
Re: Vaccum gasket thickness
Postby knobby1 » Tue Jun 10, 2025 12:39 am
Salisburytree wrote:Would anyone happen to know of Ford issuing a set thickness for the gasket between between vaccum and water pumps.
Mk6 2.4 rwd 2006
Depends on the water pump itself....I don't even use a gasket on mine...I purposely bought a pump with two recesses for O-rings...they seal better than any gasket.
Then there are pumps without the recesses which require a gasket....they always tend to leak.
Postby Salisburytree » Tue Jun 10, 2025 7:33 am
I will double check mine however I'm sure there are no recesses. Iv never noticed any leaking, the previously fitted was similar yet had a rather thin gasket
Salisburytree
Postby knobby1 » Tue Jun 10, 2025 7:45 pm
Salisburytree wrote:I will double check mine however I'm sure there are no recesses. Iv never noticed any leaking, the previously fitted was similar yet had a rather thin gasket
Some use a steel gasket, other have a steel gasket with rubber O-rings moulded into it, have also seen a fiberous type gasket used....there's lots of different manufacturers for them.
This is the most common one I see for pumps without the O-ring recesses, with the moulded in O-ring/seals:
Then theres the plain flat one which some use with the O-rings:
And another plain flat one, not sure if it's supposed to be used with O-rings or not.
As mentioned, I don't use a gasket of any kind on mine, just O-rings, and it hasn't leaked since fitting it several years ago. :roll:
Postby Salisburytree » Tue Jun 10, 2025 10:20 pm
thank you that's very useful.
I went with the thin basket in the end, I will keep an eye on it.
The thicker gasket has rubber seals however I'm having belt tension problems so the thicker one might cause me even more problems
Salisburytree
