vibration
Re: vibration
Postby knobby1 » Tue Jun 10, 2025 8:17 pm
rob4155 wrote:had my van jacked up to test driveshafts,there was play on both sides,not that much play but i could move both sides up and down,so maybe that is causing the vibration,i dont know if there should be any play on the driveshafts or not
They don't tend to playup when not under load, when under load the balls inside the inner CV joint cups get caught in the wear grooves inside the joint cup and the whole joint tends to stick in the one place and cause the whole van to bounce or wobble a bit....when the load is removed, the joint frees up and all is good with the world. Do you remember hearing the old Mini's clicking and clunking their way around a tight corner or while doing a U turn..?? Same thing applies here but it's the inner joints causing the issue....the old mini's didn't have an inner CV joint just a rubber covered steel uni joint...the 1275 Cooper S with the disc brake front end had a proper steel inner uni joint.
New shafts are arelatively cheap and easy to replace.....if she's done quite a few miles, I'd replaced them anyway. They don't last forever.
Re: vibration
Postby rob4155 » Thu Jun 12, 2025 6:59 am
am going to check bearing on drive shaft drivers side to see how tha is
rob4155
Re: vibration
Postby rob4155 » Thu Jun 12, 2025 7:04 am
van has done over 130k so i think will replace both drive shafts
rob4155
Re: vibration
Postby rob4155 » Thu Jun 12, 2025 2:00 pm
have ordered new drive shafts,do i need to drain oil before changing driveshafts
rob4155
Re: vibration
Postby metalworker0 » Thu Jun 12, 2025 2:26 pm
YES IT will pour out .but slowly ..you can use 2 litre plastic milk bottle tops/lids as temporary plug on each side . ..ive not personally tried that, only seen it mentioned on a forum, don't stuff it with blue tissue, it will only act as a wick.
if its done over 40,000 since last gear oil change ..drop the oil and put in new stuff , when done
Re: vibration
Postby gt_addict » Thu Jun 12, 2025 4:09 pm
I hope they aren’t J&R driveshafts. They aren’t the best and their customer service is appalling.
gt_addict
Re: vibration
Postby rob4155 » Thu Jun 12, 2025 7:32 pm
have them off AMC,will do an oil and filter change
rob4155
Re: vibration
Postby knobby1 » Thu Jun 12, 2025 10:10 pm
rob4155 wrote:have them off AMC,will do an oil and filter change
Oil in the gearbox, not engine....engine oil won't be affected....although new engine oil and filter is always a good thing.
Just drop the old gearbox oil and refill with new oil when the new shafts are in...job done. If the gear oil hasn't been changed relatively recently....it will probably smell horrid.
Users browsing this forum: DanMK7uk, Google Adsense [Bot], Trev_
