Engine keeps running when key is removed
Postby andypwilliamson » Tue Jul 01, 2025 3:53 pm
1999 2.5TDi Box Bus
A fault has developed very recently where the engine keep runningwhen I turn the key to the off position. However, if I turn it back to position 2 (dash lights come on) the engine then turns off.
I also have an EML and the engine is in limp mode, but I don't know if these are related or it's a separate issue.
andypwilliamson
Re: Engine keeps running when key is removed
Postby Altransit » Tue Jul 01, 2025 7:56 pm
These are almost certainly related faults. The Electronic Switch Off Solenoid (ESOS) on your EPIC pump has failed and not reacting to the switch off command, this then puts up a pump fault and causes limp-home mode.
You can prove it by stalling the engine at the same time as switching off, and then it will re-start next time without the limp.
I'm not sure if you can still get the parts to repair the ESOS, but someone else will know :)
Postby MinorMatt » Wed Jul 02, 2025 11:47 am
Suggest you have a look at my write up.
viewtopic.php?f=18&t=164093
Plungers were hard to get for a while, they are easier now but have rocketed to a stupid price. I can check if I can still get one
