silvercloud wrote:I’ve read in multiple places that skimming the head on a euro 5 2.2 engine is not recommended-
My reason for not wanting to skim the head is that I have checked and it is not warped , I have full access to engineering workshop and have no problem skimming the head if it’s needed ! Would be handier for me to mill the head that have to clean it![]()
I know very little about this engine and only go by what I have read off here , do the 2.2 have different version head gaskets ? If so I believe what I have taken off is a two notch gasket ?! Would that be standard or would that mean the head has already been done ?
Can anyone who has skimmed the euro 5 head confirm that it is ok to do and doesn’t park pistons into valves
knobby1 wrote:silvercloud wrote:I’ve read in multiple places that skimming the head on a euro 5 2.2 engine is not recommended-
You'll need to do a "piston protrusion" check to see what head gasket is required...as our metalworker0 says, taking material off the head will have the pistons closer to the valves and compression ratio will increase...not always a good thing.
metalworker0 wrote:There are different gaskets for after a head skim .when i talked about skimming it was to clean it up ..as the MLS gaskets need perfect surface to seal.
if it was warped and you needed more off, you would have to re-cut the valve seats deeper and take some off the top of the valve stems.
metalworker0 wrote:its all about piston protrusion as knobby says
they are talking about 1.8 in a connect ..dont know if same rules apply to 2.2
but it says 7 head gaskets sizes ( bare in mind this was 14 years ago ..and the supply of these gaskets may not be 7 anymore
viewtopic.php?f=54&t=88733
on other threads for 2.2, says ford themselves used two notch sometimes ...so still could be standard.
i think anything but the lightest of skims is going to have the valves sticking above the head face ..if they are now ..then it's been done before.
