DELPHI LIFT PUMP FAILURE diaphram...what does tha mean???
Postby 97transit2.5D » Fri Jul 11, 2025 9:24 am
So is there a blockage somewhere....?? ie causing higher pressure for pump to pump into or is the thing faulty...3000km after installation
from diesel injection pumps uk.
https://injectionpumps.co.uk/product/li ... hi-hfp521/
has anyone had similar problem...is there a blcokage somewhere or is this lift pump shite???
97transit2.5D
Re: DELPHI LIFT PUMP FAILURE diaphram...what does tha mean??
Postby dumper » Fri Jul 11, 2025 11:27 am
What are your symptoms and how did you get to this conclusion and what model of transit have you
Postby V184 » Mon Jul 14, 2025 9:20 pm
97transit2.5D wrote:So is there a blockage somewhere....?? ie causing higher pressure for pump to pump into or is the thing faulty...3000km after installation
Remove the filter and get someone to spin the engine over on the key fuel should pi55 everywhere if it doesn't theirs probably a blockage, have you got the pipes on the right way round on the lift pump ?
V184
Postby 97transit2.5D » Fri Jul 18, 2025 7:59 am
it has done 7000km on the current lift pump
97transit2.5D
Postby 97transit2.5D » Fri Jul 18, 2025 8:00 am
can a lectric pump be added?
97transit2.5D
